Sorry but it sounds like a controller fault, need new controller Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
SOURCE: When I plug in my jet 3 ultra the ammeter reads 0.
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
SOURCE: Pride Jet 2 power chair with with 3 red and 3
Hi. The fault code you have is called the "Inhibit active".
It can be caused by a blown charger fuse, which causes the charger inhibit to activate.
Also if the 3-pin charger inhibit connector is not plugged in properly, or the connector is faulty, then the charger inhibit feature will activate.
Hope this helps. Neil.
SOURCE: Constant flashing lights,all three of
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
