My GE top load washer will fill with water, agitate and wash, but does not drain or spin. I turned on my washer and 1 hour later it was still running and had moved to a new cycle. I could not get it to drain or rinse on any cycle.
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it. Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
SOURCE: ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
