Irulu 9 inch Android Tablet PC, 4.2.2 Jelly Bean OS, Dual Core, Allwinner A20 CPU, Dual Cameras, 5 Point Capacitive Touch Screen, 8GB Storage, with Keyboard case Logo
Forgotten pin locked out reset does not work - Irulu 9 inch Android Tablet PC, 4.2.2 Jelly Bean OS, Dual Core, Allwinner A20 CPU, Dual Cameras, 5 Point Capacitive Touch Screen, 8GB Storage, with Keyboard case
How do I reset my PIN number to get into my laptop
which tablet u will nedd to hard reset it u will loose everything on the tablet if u not backed up before you forgot password
How can I reset my tablet?
    1. Here's how to execute a factory reset:
      1. Turn your tablet off and remove the SD card, if there is one.
      2. Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
      Forgot your tablet's password? - TechAdvisory.org
      www.techadvisory.org/2013/03/forgot-your-tablets-password/
    Feedback
  1. Forgotten Pattern, PIN or Password on an Android device
    acer.custhelp.com/.../forgotten-pattern,-pin-or-password-on-an-android-...
    What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
How do I recover from a forgotten password?
If you have forgotten your 4-digit pin, the only solution is to do a factory reset. Here are the instructions on how to perform a factory reset: nabi Show the world what you can do
My tablet says...your tablet is locked.please contact your administrator could u please tell me how to fix this ty
If you have forgotten your PIN code, or unlock pattern, you may find one of these pages of use to you. The last resort would be a reset to the factory settings/image.
Unlock forgottten password pattern lock of Android Tablet
How to unlock android tablet after forgetting pattern lock
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
There is going to be overlap among those pages, but some have product specific information. You may have to consult a manufacturer's support page or documents for specifics if none of those help.
I post on behalf of HP.
Need to set up pin number
That's a tough one! You may have to reset the Kindle if you don't recall it. Try familiar things that you may have set and forgotten. Or read this as this may be what has haoppened with you. http://the-digital-reader.com/2012/05/05/warning-latest-kindle-fire-update-turns-on-passwords-by-default/
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
Top Irulu Tablets & eReaders Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Paul Bade
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
