Cars & Trucks Logo
A
Anonymous Posted on Jan 17, 2016
Lost key to 2002 Mustang 3.8 what's the cheapest fastest way to fix? Can I bypass the anti theft system? Buy new ignition and key will that work?
2answers
I am looking for a wiring diagram for the PCM on a 2002 Saturn L series 200
Saturn was owned by general motors, so I would recommend calling GM and asking them to email you the diagram. Their phone number is 1 (800) 462-8782.
Thank you.
How do I disconnect the anti theft on my 2001 ford mustang I lost the key to it but I had another one made
you dont and if had key cut should work or did you just have a non chip key cut which wont work
2003 ford mustang gt anti theft light flashing engine will turn over but will not start
From my experience...
A non PATS coded key SHOULD not turn the STARTER...!
If ANTI-THEFT were invoked... you can attain a not start condition which the Owners Manual says must be cleared by the dealer.
A working PATS key should disable the anti theft... by turning the ignition on... ELSE try your other key.
The SecuriLock [PATS]
passive anti-theft system is not compatible with
non-Ford aftermarket remote start systems. Use of these systems may
result in vehicle starting problems and a loss of security protection.
Owners Guide (post-2002-fmt)
USA English (fus)
OWNERS MANUAL
Ford 2003 Mustang Owner Manual
SHOP MANUAL
Ford 2003 Mustang Workshop Manual
What would make the theft light not come on at all
99 F-150 ignition/anti-theft question - Ford F150 Forum - FordF150.net
www.fordf150.net > ... > Electrical (Everything except audio systems)
Sep 16, 2009 - I had 2 keys for the truck, one worked perfectly fine, the other wouldunlock the ... over but the anti-theft light flashes and the engine won't actually start. ...Should I just spend the $80 for the switch and hope that is all it needs? ... for Fordkeys (Later 1998-newer Ford, Lincoln, Mercury) ... Mustang 1998 - 2001
electrical - Can I disable antitheft (PATS) on 03 Mustang ...
mechanics.stackexchange.com/questions/.../can-i-disable-antitheft-pats-o...
Jan 4, 2012 - So my question is: Is there a way to just disable the anti-theft system? ... This will make the car always 'see' a key with a chip. ... as they are usually intertwined with the anti-theft system to ensure the engine will not start. ... Where is the Wiper Relay/Control Module located on a 1994-1998 Ford Mustang??? 7.
How to Turn off Theft System on Cars: 7 Steps
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowJump to Questions and Answers - Be the first to ask a question about this topic: ... Itwill not start and your battery will die. ... Reset a Check Engine Light ... Thanks to allauthors for creating a page that has been ... How to. Make Oat Flour. Cook Bacon in the Oven ... People are incredibly helpful and open to new ideas ...
2002. Why has anti lock cut off ignition and fuel?
Anti THEFT cuts off fuel pump and the ignition module. That is what it is for. The theft light on the dash should be on too. Something tripped the anti-theft system Try resetting the anti-theft module by locking and unlocking the drivers door with the key.
Hello I have a1995 Mustang that tore up and I took
yes as when you change an ignition switch it has to be sync to the computer so it knows the correct keys are being used and the car is not being stolen.
Lost keys to 2001 mustang and need to bypass anti theft
So I can use my 2001 Mustang 4.6 L that changed the ignition out and then I changed the computer out now that's flashing or it won't let it start and it starts to die
1helpful
Anti theft system
The chip is in the key. Either the key has lost it's program or the transceiver is not recognising the key. Try another key if you have one.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
