PFSS2MJYISS MODEL 22 CU FT
Http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls
·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open
·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset
·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
SOURCE: GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
SOURCE: Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
SOURCE: looking for cu. ft. info on fridge - hotpoint
It's in the model number.
ctx14<---- 14 cu ft.
SOURCE: Kenmore 1.8 cu. ft. Compact Refrigerator stopped running and won't turn back on?
It is really hard to say why it shut down, but my best advice is to make a service appt. asap to have the problem looked at.
SOURCE: can you give me the measurements height width
Depth Cab. Width Door Width Cab. Height Overall Height
Model size "A" "B" "C" "D" "E"
STANDARD MODELS
19 cu.ft. 30 3/4" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
21 cu.ft. 29 3/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
22 cu.ft. 30 3/4" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
INTEGRATED MODELS
19 cu.ft. 31 1/2" 29 1/2" 30 1/8" 65 1/2" 66 1/2"
22 cu.ft. 31 1/2" 32 1/2" 33 1/8" 65 1/2" 66 1/2"
ARCHITECT® SERIES MODELS
19 cu.ft. 32 7/8" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
22 cu.ft. 32 7/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
cancel that, it's his CO2 detector, LOL
