Pictures distorted, was using rabbit ears for 3 yrs. all of a sudden it stopped working, added new indoor antenna (Clear TV HDTV Digital Antenna), still not working. Westinghouse said the cable company may have encrypted the basic channels. I don't want cable just the basic channels. ( The tv manufacturer is Westinghouse, Model #LTV-32w6 HD says Re-furbished no serial no., it's about 4 years old and it's digital and analog both. ) Please help?
Talk with a tv technician as to the capabilities of the tv set but you may need a better outdoor antenna if the signal has changed from am to digital or fm in your viewing area
If by distorted you mean pixelated into cubes , then yes your problem is a signal strength , ck to make sure water hasn't got down into cable antenna lead (powdered Inside) and corroded the thing up , and that all elements of antenna are still there (wind does wonders) if a tree has grown up into block your view of the tv station it will not work as well
you did not mention the model of your tv but id bet in the channel set-up screen it has a signal strength meter , ck it maybe its just not enough to get a picture
