2 days ago our washing machine suddenly stopped filling when set to Cold/Cold cycle. The machine makes a electrical buzzing noise when turning it on to see if the water will come out. Seems to work fine when using hot water but that's it. If you set it to Hot/Cold its only hot water, Warm/Cold its only hot water.
SOURCE: washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
SOURCE: Rinse cycle, water won't work
It sounds like you either use warm or hot water for the wash cycle. If this is the case, you probably have a cold water solenoid problem on your water inlet valve (also known as a mixing valve on some washers). Most people use warm or hot water on the wash cycle. The water inlet valve has two solenoids. One for hot and one for cold. It uses a combination of the hot and cold solenoids to make warm water. The rinse cycle on most washers is a cold water rinse only, however. This would explain why the water appears to flow normally when it fills during the wash, and only trickles when it rinses. If you live in an area that has hard water, or if you use well water, these valves commonly clog with sediment. You can shut off the water, remove the hoses, and attempt to clean the sediment screens to see if the water flow improves. If it doesn't, you will need to replace the valve. The following link epxlains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
I know the link says this is for a Kenmore or Whirlpool, but also applies to a Roper. A replacement valve can be ordered on line at searspartsdirect.com. Just type in the model number and the part you need is located under the "Controls and Rear Panel" heading as item number 18 (part #285805). This is a very simple and inexpensive fix if you wish to perform the repairs youself. Not to mention, you can potentially will save hundreds by avoiding the labor charges of a service call. I hope this helps you. If you require additional assistance, please let me know. Hopefully, a good cleaning will do and you won't require parts.
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
SOURCE: Roper washing machine not going through rinse cycle.
Good Morning,
Sounds like your cold water valve is not opening. If you are handy with a Multimeter check the selector switch that you use to set your cold water for good continuity when you activate it. You should have a good steady reading on the meter. If the meter is fluctuating or has no reading at all the switch is bad. If the switch checks out good, check to see if there is voltage to the cold water valve terminals when the machine is calling for cold water. If there is no voltage, you will have to locate the relay or source that supplies this voltage and replace it. If there is voltage the valve is faulty and needs to be replaced.
I hope I helped you today.
