Loose bottom thread-no matter what the top tension number is set at. What is the ideal starting top tension number value?
Factory standard tension for upper thread is the midway point between the high and low number. However, that tension dial is meant to be used for tweaking tension. Generally, tweaking is required whenever the type of fabric, needle, or thread are changed, ie thicker fabric like denim should have a different upper tension setting than fine chiffon. To be successful with tension settings, one must become comfortable adjusting the upper tension.
NOTE: Accurate tension is achieved when the upper thread and bobbin thread meet in the middle of the fabric.
Understanding Bobbin Tension
