Intuit QuickBooks Pro 2010 Full Version for PC (28287024175) Logo
J
John Later Posted on Jan 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the amazing facts of QuickBooks ?
I am using the QB's i am not familiar of much functions in QuickBooks. How can i get that ?
Betty Reese
Level 2:
Habit-Forming:
New Friend:
  • Expert 177 Answers
  • Posted on Sep 22, 2017
Betty Reese
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
177
Questions
Helped
44842
Points
381
Check all the functions across the top one at a time. Each function you click on will bring up a pulldown menu.You should click on each one shown. When another screen appears you can see what can be done. Great program, but does take a little time to learn. Good luck!
1 Related Answer
Anonymous
  • 34 Answers
  • Posted on Feb 12, 2010
SOURCE: Convert QB POS to QB Premier Accountant
a) If you previously syncronized POS 2008 with the financial product, then no, you cannot syncronize the data again, unless you tag each transaction (for the whole years) as "unsent".
b) If you have never syncronized POS 2008 with any QuickBooks Financial product, then yes, you can syncronize/download the data into QB 2009 Accountant Edition.
Before you do either: Make sure you do not already have 2008 data in your file.
2answers
2answers
Error installing quickbooks 2005
I don't know what type of error you face while installation of QuickBooks but i share some of Intuit common error so choose the right one for you Links for installation errors . if still not able to get and need any technical help follow Intuit Tech Support .
3answers
I am trying to instal quickbooks pro 2008 but error 1603
Error 1603 is related to insufficient rights to install QB. Please follow these steps to resolve this issue. Assuming you have Win XP. 32 Bit OS.
1. Remove QB from Start>control panel>Add/remove programs. {IF YOU FIND ANY QB INSTALLED].
2. Rename all intuit folders to Intuit-old. You wil find these folders here:
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then install QB using QuickBooks.msi . You will find it inside QBooks folder in your QB disc. Right click on the DVD / CD drive and click Open/Explore. Then go to Qbooks folder, find Quickbooks.msi and then run it. Follow the wizard and then install it.
IF STILL ISSUE IS UNRESOLVED, THEN REMOVE AND INSTALL MICROSOFT .NET FRAMEWORK 2.0 SP2. To do it, please follow.
1. Download and install .NET removal tool from:
http://public.blu.livefilestore.com/y1pM-hUF1x_Oqpme4sYbkLY1eFfh7z7FTyANwGAK1PQgJMwhILtFzMj7WXQJtjfH39GalpsBeQRzeQHXRlbO9w1gA/dotnetfx_cleanup_tool.zip?download&psid=1
then save it and unzip it . Then run it. Select Allversions in the box where it will ask to remove .net framework from the computer.
2. Download .NET framework 2.0 SP1 and then install it . you can download it from:
http://www.microsoft.com/downloads/en/details.aspx?familyid=5b2c0358-915b-4eb5-9b1d-10e506da9d0f&displaylang=en
click on DOWNLOAD next to NetFx20SP2_x86.exe. download it and install it.
3. Restart your computer and then again install QB.
IF STILL YOU GET ANY ISSUE, REPLY WITH FOLL :
1. WINDOWS VERSION.
2. are you installing QB using a disc or downloading from the Internet?
3. Any Antivirus on the computer?
2answers
Error 7149 Quickbooks
Thanks, that worked! I first spent a half-hour on the phone with the non-tech support at Intuit and he walked me through that download. What the download does is update your original QB 2005 RC1 version to the RC9 version ("Release Candidate") where they've fixed some things (such as the Flash 7 install problem). Here's what we did:
1.) Removed Flash ActiveX 9 in Add/Remove Programs
2.) Downloaded webpatch from QB site (start here: http://www.quickbooks.com/Help...
3.) Closed QB (couldn't open it anyway)
4.) Installed patch.
5.) Restarted computer.
6.) QB worked!
Thanks for your postings. I hope this helps.
Thanks.
I am using Quickbooks 2002 First screen says: This file was not closed in the previous session. Rolling back to last fully recorded transaction." Then I click OK and get the message: "Quickbooks has...
That is an "Old QB Software version" installed in to a "Newer Version of Windows" issue.
QB 2002 most likely works best with Win 98 or 2000.
For your best functioning on your PC, I would ONLY do QuickBooks entries when your PC has just been freshly turned on and no other programs have been running first. Also "Pause" or temporarily "Exit" any background running software like Win Defender and/or any Anti-virus programs. Call QuickBooks and ask them how you could go about Up Grading your QB version to a more Windows compatible version without having to purchase EACH version to "UPDATE" your pre-existing database/files so they are not lost or dysfunctional. They once sent me disks to jump 2 versions and they charged me less than 50 bucks but that was a few years back. Good Luck!
4helpful
4answers
Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
