Roger Hicks Posted on Jan 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i hook up my tablet to a epson wf3640 - Epson Office Equipment & Supplies
L Pfaff
Level 3:
Top Expert:
  • Epson Master 11,573 Answers
  • Posted on Jan 21, 2016
L Pfaff
Epson Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587233
Points
181713
If they both have blue tooth, use it. Other wise use a USB cable from your device to printer. Press the helpful button.
Or locate your manual here, or talk to the support staff
Epson WorkForce WF 3640 All in One Printer
2answers
Model WF3640. What does error code 0x9e mean?
I had this problem twice, spent many hours on it but all recommendations I found in the web failed. In both cases I ended up with with the local Epson repair centre. In both cases they fixed the problem quickly, in one case even free of charge. As I do not have an idea of what they could have done I cannot give an answer to your question. However, I recommend that you should not waste your time and contact local Epson service.
Have a WF3640 all in one printer and it just stopped working .Power is good coming in red light is on in side but will not power up.
If your Epson WF3640 printer is not powering up, there could be a few possible reasons for this issue. Here are some steps you can try:
  1. Check the power cord: Make sure that the power cord is properly plugged into the wall outlet and the printer. Try using a different power outlet to ensure that the problem is not with the power source.
  2. Check the power button: Ensure that the power button is not stuck and that it is making proper contact with the printer's internal switch.
  3. Reset the printer: Unplug the printer from the power outlet, wait for a few minutes, and then plug it back in. This can help reset the printer and clear any internal errors.
  4. Check for hardware issues: If the above steps do not work, there could be a hardware issue with the printer. You can try contacting Epson customer support for assistance or take the printer to a professional repair service.
Note: If your printer is still under warranty, it is recommended to contact Epson customer support for assistance.
2answers
I use my EPSON WF3640 rarely and it seem my ink heads are always plugged - is there any way to clean the heads without using up all my ink
I would ask a company that refills ( re-furbish, re-build, etc.) ink cartridges.
If you have none in your area, try asking your questions on-line.
God bless your efforts.
How do I change the security key of a wifi network on my Epson wf3640 printer
Wi-Fi is rapidly replacing wired LAN in homes and offices. This is the reason most high-end printers now come with Wi-Fi built into them. Now you can print documents wirelessly without attaching cables. However, before you print, you need to connect and configure your printer to print over a Wi-Fi connection. In order for the wifi to work, your printer and your computer must connect to the same wifi router or to an access point/repeater/extender connected to the same router.
1. Open Internet Explorer, on the address bar type 192.168.1.1
2. There's no username and type admin on the password. If admin didn't work, use your own password.
3. When you have the Setup Page open, click on Wireless Tab, then click on the sub-tab Wireless Security.
4. There you can see the Security Mode. If the mode is set to WEP, the WEP Key 1 is your wireless key. If the mode is set to the WPA-Personal, the Passphrase or the WPA Shared Key is your wireless key/PIN.try this steps and fix problems let if you have facing this problems call canon printer technical support Experts toll-free number 1-800-213-8289 for get online help. Epson Wireless Printer Support Number 1 800 610 6962 Help
Whenever i try to print an saved email or anything my tablet keeps showing me unfortunately your print spooler has stopped.So i called my printers company called Epson and they said to call digiland
The Epson folks are probably right - the problem is most likely with the tablet, and not the printer. The "spooler" is part of the software driver setup that the tablet uses to prepare the file to be printed for transmittal to the printer. The best option here is to uninstall and reinstall the printer to the tablet and try again. Usually that solves issues with print spoolers.
1helpful
How to clear Epson WF3640 paper jam?
Hello, the only way to clean the jam is to first unplug the power, take off the back and look for the paper, pull all the paper out and if you can see the jam pull that out, you may have to get twizzers or plyers to do it. If you can't get the printer to paper feed out.
Www epson com support
Look for apps that can be compatible with printers, i've never heard of that before though.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
