Electrical Supplies Logo
Posted on Jan 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pictures of the auto-choke setup on the carburetor?
FG6000MK 11HP 5700W. Auto-choke is not working from someone previously working on it and I'm not sure it is on properly. Also, where can you find a service manual?
JOHN PACE
Level 2:
Sergeant:
  • Expert 227 Answers
  • Posted on Jan 22, 2016
JOHN PACE
Expert
Level 2:
Sergeant:
Answers
227
Questions
0
Helped
72384
Points
532
YOU CAN GOOGLE IT INTO ADDRESS SLOT AND HIT ENTER OR CALL MANUFACTURER WITH MODEL & SERIAL NUMBERS
2answers
1989vintage 454 in RV will not disengage the choke release resulting in 2000rpm steady 'idle' milage 28000. RV has been in campground for 3yrs. Engine run up every 30 days.
Possibly could be a throttle position sensor, outside of that I would recommend replacing the choke cable, and maybe the choke itself.
Mar 18, 2017 • RVs
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
What would make a McCulloch FG6000MK 11 HP generator start and idle fine but not able to rev-up and generate power.
Have to an ultrasinic cleaning of the carburetor and see if that will clean up the problem,
Bad on parts though most are NLA. but a carburetor from a Honda 11hp horizonal might work on this Chinese Honda cloned engine.
Ts410runs with choke turn choke off cuts out
A common problem is clogged jets in your carburetor. Choke bypasses the jets. Clogging due to old fuel happens much faster when there is ethanol in the fuel. Solution: Disassemble and clean out the carbs. If you're lucky you can try putting some sea foam (available at Walmart or auto store) and run it through the engine to unclog the carburetor without disassembley.
Oct 20, 2013 • Motorcycles
2helpful
McCulloch Generator model FG6000mk 11hp run good until I turn on generator then stop running do you think the generator bad and can it be rebuild ?
I did not understand how you turn on generator, as it is always turned on.
If you use the ON/OFF switch it is stopping the prime mover.
If you reset the AC breaker without load, and it stops - it means that you have short circuit after the breaker. Check the output receptacles.
Try this link:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FG6000MK-7096FG6024-966991401.pdf
Mcculloch generator 5700W 11 hp
Sounds like your choke is not closed correctly when you first start the genset. Remove the air filter and look at the throttle plate. It should be closed with a hair line gap. With your finger you should feel very little play on the throttle plate. As you open the choke, you should be able to open it all the way once the engine has reached a hotter temperature. If the engine is still cold and your opening the choke all the way, it will try to die out.
2answers
McCulloch 11HP FG6000MK surging
it sounds like the govener screw needs to be adjusted by turning it clockwise and then you may have to tweek the throttle screw. hopefully that will take care of it.
Top McCulloch Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
