Samsung SCH-a870 Cellular Phone Logo
L
Lee DeWitt Posted on Jan 22, 2016
I would like to delete all my contacts off this phone at the same time. Have tried to reset but it tells me that it reset will not effect my contact settings.
5 Related Answers
Anonymous
  • 175 Answers
  • Posted on Dec 15, 2007
SOURCE: Deleting all contacts pin
hi there its better to reset the phone just inter this code *2767*3855# don't forget to save your contacts. ok
peace!
Anonymous
  • 48 Answers
  • Posted on May 04, 2008
SOURCE: Samsung SCH-U740 Master Reset
Let me elaborate. On your phone press the:
1. Menu--scroll to Tools & Settings---press OK
2. Look for Security, press OK
3. Enter the last 4 digits of your phone #, or whatever you set the lock code to.
4. There should be an option to delete contacts. Becareful not to press the Reset Default option, for it will erase everything (ringtones, pix, filx, screensavers, etc..)
**If the Security option is not seen in the Tools and Settings, then choose Call Settings or Phone Settings. It should be in one of these.
Anonymous
  • 3 Answers
  • Posted on Jan 09, 2009
SOURCE: Cant copy phonebook contacts from sim card to phone memory?
Go this way
Menu > Phonebook > Options
Scroll down to Move and select.
Select Multiple from the pop out.
In the list just check All or whatever contacts you want.
HTH
Anonymous
  • Posted on Jan 18, 2009
SOURCE: Need to delete all contacts so I can sell my phone
open the contact list, higlight the contact, press options, higlight erase press ok.
you have to delete them one at a time.
Anonymous
  • 879 Answers
  • Posted on Aug 12, 2012
SOURCE: i had deleted my contacts from wave 3 how can i recover
Contact the persons to get their details and re-save it. What else can do?
When I go on contacts on my I phone 6 plus there is no plus icon so I cannot add contacts
Is it possible you have used all the available slots to save contacts too. Ie. Some phones allow only 150-200 contacts to be saved at any one time. Failing that check your overall memory (usually settings, my device /phone, storage. If your phone has to much stored on it, it will affect the performance of your phone and is ability to save effectively, try deleting large files off your phone through file manager, be sure to save somewhere else if you want to keep the files you delete to free up space.
Mar 06, 2015 • Cell Phones
3answers
I deleted my contacts on my lg zone 1 phone how do I restore my contacts
You can try GT Recovery for Android
Accidently deleted some contacts on your android phone ? A simple app from play store can help you from big headache of Restoring deleted Contacts.
Here on video we Show you step-by-step guide to recover deleted contacts on android device.
With this way you can recover deleted contacts on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Twitter:https://twitter.com/GtRecoveryapp
I have reset the GT-C3222 but I lost my all contacts from the Phone memory. Can any one hlepme to get those contacts back with deleted Sent, Draft messages?
no when you reset is like that the shop never tell you is like that last time i update my nokia x6 also like that never mind .
How i can delete my phone contacts in one instance. I am unable to do that.
...on Apple IPhone - how do I do this? I appear to be bale to delete one at a time....since the contacts menu does not have an (EDIT) feature to multiple delete contacts, the only way to do is use the normal way .. RO
please tell me the refresh code for nokia 6300...how to retrieve my deleted contacts?...sir there is no refresh code for nokia there is hard reseting which refresh your phone it works fast hard reseting code *#7780#
How do you delete the entire contact list on the motorola i760 phone
HI,
Frankly speaking their is no way you can delete entire contact list in Motorola i760 phone at a time.You can only delete one by one.But there is way to delete it but its not a very best practice.Two methods to delete the contacts.you choose the way you want to delete
Reset will delete all contacts and phone details-
menu/settings/advanced/connectivity/master reset. Code is 6 zeros.
Else you can try this
http://handheld.softpedia.com/progDownload/PIM-Backup-Download-35107.html
download PIMBackup.This is application is to delete all contacts and it also has many other functions you can use it.
click OPTIONS->DELETE ALL->CONTACTS
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
1helpful
Samsung GT-S5230\r\n
I don't know if this would help but i did this once when i couldn't save my contacts abit similar.
well what i did was that i went to my settings reseted my phone don't master reset just reset when it resets just turn it off. take out the battery, sim card check if theres any dust in your phone if there is blow it all out chuck your sim card back in, battery too and turn it back ongo on to contact list go on the number you want to delet click on options scroll down to delete and click yes...
goodluck:)
please rate this solution.
If this solution does not work just tell me and i will try to help you again...
1helpful
I cannot delete or edit existing contacts in my address book
Remove battery and reinsert (power cycle). I know, doesn't make sense but it worked for me and others.
7helpful
3helpful
2answers
How to delete contacts on Blackjack II..???
yellow!!
here's some tip:
to delete contact:
  1. While in standby mode, press the right soft key for Contacts
  2. Highlight the desired Contact, using the navigation keys
  3. Press the right soft key for Menu
  4. Select Delete
  5. Press the left soft key for Yes to confirm the Contact deletion
to delete all contact:
The only way to delete all Contacts, other than to manually delete them one by one, is to perform a reset on the handset.
NOTE: RESETING YOUR PHONE WILL DELETE ALL INFORMATION ON YOUR PHONES MEMORY
TO RESET YOUR PHONE CALL YOUR SERVICE PROVIDER..
;P
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
