Dyson DC-35 Digital Slim Cordless Multi-Floor Vacuum - - Logo
D
Doris Croslin Posted on Jan 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you buy the head off of dyson fluffy and will it fit the dyson 35?
  • Official Brand Answer 2,572 Answers
  • Posted on Feb 01, 2016
AskDyson
Level 0:
Answers
2572
Questions
0
Helped
1769808
Points
6009
Hi, it's Allan at Dyson.
The soft roller attachment is only for use on selected V6 machines. This unfortunately means that previous models such as the DC35 and DC44 are not compatible.
If you have any other questions feel free to give Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK).
I hope this helps.
Best wishes,
Allan
tip
Dyson Fluffy DC74 cordless vacuum cleaner - Getting started
How to assemble, recharge, use and empty your new Dyson Fluffy DC74 Motorhead or Motorhead Complete cordless vacuum cleaner.
on Nov 27, 2014 • Dyson Vacuums
2helpful
What is the difference between the v6 fluffy and the v6 absolute?
The Dyson V6 Fluffy has a similar design and the digital motor V6 technology but comes with a different type of cleaner head, one that has a full-width soft nylon roller with carbon fibre filaments.
This picks up large debris, while the carbon fibre filaments pick up fine dust. It "sucks up as much dust as even a corded vacuum," claims Dyson.
One of the main differences between the Fluffy and the top-of-the-line Absolute is that it doesn't have the post-motor filtration as the more expensive model, but will still remove pet hair and ground in-dirt.
Dyson v6 fluffy is stopping and starting
Hi, this happens when the PCB detects a blockage. Take the filter out and then try it. If it no longer goes for only 5 seconds then your filter needs washed. Wash the filter in your washing machine. Reply please
Hi, I have a dyson v6 absolute (UK version), which has a direct drive cleaner head. Will a soft roller head (aka fluffy head) fit and work on this machine?
Hi, it's Allan from Dyson.
I'm sorry we haven't been in touch about this sooner.
It depends where you are.
For example, the UK V6 Absolute has not been tested with the soft roller head and it will not fit.
I would recommend contacting Dyson directly in your region to discuss this further.
Please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Best wishes,
Allan
Power head not working
Hi, it sounds like your motor is gone. That was the sound i had from my dyson dc07 animal i took it apart and found that the brushes had burnt the armature on the motor. I ordered a new motor and fitted it back together with the help from an espares video. I bought a genuine dyson motor they come in a black box and it is a lot cheaper than buying a new dyson. It was the popping sound that i had .Hope this is of some help to you. Always unplug the hoover when working on it.
Why does it not fit?
Hi Clint, it's Jack at Dyson.
DC24 is not compatible with the original Mini turbine head as this tool is engineered to work with the performance characteristics of our full size upright and canister vacuums.
However, we do make a Mini turbine head which is compatible with DC24 - for help ordering this, I would encourage you to contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA). Once we've taken the serial number of your machine we'll be able to confirm the correct Mini turbine head for your vacuum.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Question re hose and head
Hi There,
Ok so the hose definitely cannot be interchanged, all the dysons have a different (slightly) fitting where the hose clips to the vacuum. The head I think can be fitted from a DC19. To be sure I would buy the correct one for your model. Dyson have a bad habit of using different fittings for different models to force you into buying the proper dyson one. With the DC05 and earlier you could adapt heads from normal vacuums but they stopped it from dc08 on.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
