make sure that the truck is in the ready to move configuration--
bucket properly stowed booms in etc as there may be micro switches that will not allow pressure to return from the cylinders until this is all achieved
The system has safety devices that will not allow operation until it is properly leveled or will not allow stabilizer operation until the machine has been properly made ready for travel
read your operators hand book and safety instructions
In section 8 of your instructions is the "Door handing" programming instructions Link here: http://s7d5.scene7.com/is/content/BDHHI/Website%20Content/Kwikset/Resources/KwiksetSmartCodeManual.pdf
You need to carefully go through this programming routine without interruption. That should fix it for you. Good luck!
Look in hand book for manual operation of roof.
The handle is located side of dash,insert as shown.
Start manual operation
You do not have to do the full opening/closure
After the operation starts and releases rear flap remove handle,
Start car.Check electric operation of roof
This op should have reset it
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDS50A2020&LOC=3 are the operation instructions incase you lost or misplaced your owners manual. here are the entire operation instructionds including the lamp chanbe directions and where to get a direct replacement lamp. but i would first look at the several lamp suppliers that are listed here on this web-site, good luck Larry Dillon AKA techman
L held = shield
R held = shield
R or L held with direction = dodge
Z + direction = grab
A = attack + corresponding direction
A and direction pushed at the same time = Smash Attack
B+ corresponding direction = special attack
D-Pad = taunt
Hi david - I could tell you how to do it but I believe it is better to see how in the manual and then also you'll have one in case you need it later for something. Just follow the link below to download the manual. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. (link says 5631 but just go there. It's the right one as you'll see) Thanks.
