LG BH9431PW LG HOME THEATER SYSTEM will not play a cd. or dvd , receiver automatically ejects disk
SOURCE: phillips 6500 home theater system
Turn the power off, and then unplug the home theater from the wall outlet. Plug it back in after about 30 seconds, and turn it back on. If it still won't eject, then the HTS needs repair. Philips will replace it if it is still in warranty.
SOURCE: DAV DZ100 - Not working
2 options comes in my mind...
Put software upgrading CD manually in player and let it finish software upgrade process.
If this trick doesn't work, you need to replace digital process board or need to replace on board ROM, if you can.
let me know if you need further info.
SOURCE: We have a Samsung Digital
Samsung Home Theater Systems
have a Dealer Lock or
Tray Lock Function that prevents
the disc tray from being opened.
There are four procedures
for turning off the Dealer
Lock function. Try one, then
the other, to see which works
on your system.
Unlocking Procedure 1
To turn off the Dealer
Lock function, follow these
steps:
Note: Repeating
the two steps above turns
the dealer lock on again.
Unlocking Procedure 2
steps
Note: Repeating
Unlocking Procedure 3
steps
Note: Repeating
the two steps above turns Dealer Lock on again.
Unlocking Procedure 4
steps
The Dealer Lock feature
is mainly used by retailers
to ensure that the display
discs are not removed. However,
parents of young children
may find this feature very useful
as well.
SOURCE: I cant eject cd/dvd changer.
Try first unplugging unit from main, and holding the cancel button.
If that does not work try the following:
Hold at the same time the stop button on the main unit and key >10 on the remote control at the same time for about 5 seconds, until you get the word "initialised" on display. This will reset the unit to factory settings.
SOURCE: LG compact home theater system: LFD790, how do I
Hold stop botton down for 15 seconds. It works!
