I get to "profiles" .It says power saving mode but no help as to deactivate it
SOURCE: my unit is Nokia E52.please
As Nokia E52 is the ESSENTIAL MODEL Mobiles, As its in high Range of Applications Used to get it's Visual.
Here are the Fiew tips to DEACTIVATE the Power Saving Mode.
1. First Switch on your Mobile.
2. After completing it's Process, Click the Menu Button.
3. Go to the Settings
4. Settings -> Display Settings
5. Go to the Power Saver Mode Option,
6. Change the Mode of Operation from ON to OFF
7. As Now go to the Screensaver Settings,
Change the Time-Out time to your Favour.(Not Less than 15 Secs)
7. As after this setting is Done, Restart you Mobile Phone
But Kindly Connect your Phone with Nokia PC Suit and Update your Phone to keep your phone upto date of the Latest firmware.
To get the Updater, Click the Link Below
http://www.nokia.com.sg/support/download-software/phone-software-update
Click the Download Button in Update using your PC section, There you can find Nokia Software Updater, Select your Language.
SOURCE: The back light keeps going
First Press the power on /off button, then you'll see a list. Scroll to the end of list and you'll see powersaving. You can deactivate the powersaving mode from there.
SOURCE: How do I deactivate the
hello, you go to the settings where you click the power save mode was on..then click off..
SOURCE: How do i deactivate power
go tools, settings,general, personalization, display, power saver, try to increase up to 90 seconds, this cannot be deactivated due to the phone save power consumption to avoid your phone low battery in just few hours.. or try ligth time out increase to make it more time on standby if your reading some message..
