My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
SOURCE: LG Dryer 5977 will not dry
If one of the two thermal fuses are blown you will not get heat. Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot. Often this is caused by not enough air flow through the machine. Check and make sure your exhaust vent is not clogged. Clean it the best you can to get all the lint, dead mice, bird nests, etc. out. Also make sure air is blowing out of the machine when it is turned on. If not you have a blower problem.
SOURCE: Dryer does not dry clothes
If the dryer tumbles but does not warm up, you either have
one or two blown thermal fuses, a burned out element if it’s electric, or a
burned out igniter if it’s gas. If one of the two thermal fuses are blown you will not
have a blower problem. The thermal fuses are located on the element casing. They each have two wires coming out of
them. They are about 3/4 inch round with
screw ears on the sides so they are about 1 1/2 inch long and about an inch
across. With a multimeter, check the
continuity across the terminals. If
there is no continuity the fuse needs to be replaced. To check the element(s), you can either visually look and
see if it is broken or check the continuity with a multimeter. No continuity means the element is
broken. Replace if necessary. To check for a broken igniter, take out the old one and
look at it. If it looks broken or very
burned, replace it.
SOURCE: Not properly drying
If you remove the front cover hitting the reset switch is rather easy. However I did that the other day and only got 1 load done before it tripped again.
I just picked this dryer up used from a buddy the other day and am already having trouble. Also... It runs very loud. How loud is yours complared to the washer?
SOURCE: dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this:
Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside.
Gas valve coils
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
