Cobra 19 classic
I would open up the radio and look for burnt traces, primarily by the output transistor and near where the power comes in. If you have another radio near by (within several feet) and it transmits on the same channel that your radio is on, can you hear it?? If you transmit on your radio, does the working one hear you? If you open your squelch, does it make noise?? If you transmit, does the RF power meter go up?? If any of these questions are YES, then there is a good possibility that your ANTENNA SWITCHING diodes are shorted or open. The TX diode is probably open and your RX diode is shorted. OR both. If the other radio is hearing you, and you are hearing the other radio, then the radio section is very likely OK. The diodes switching the antenna between RX and TX often fail, especially if there has been a lightning strike in the vicinity. It doesn't matter if your radio is on or not, or if you have a surge protector, a nearby lighting strike can take these diodes out.
If you don't have as much as a Channel number coming up on your radio, then the problem is most lkely somewhere in the radios internal power supply.
