Question about HP Officejet 100 Mobile Inkjet Printer, Bluetooth-Enabled
All lights are blinking, it's not possible to turn printer down, only a hard reset helps.
Hello, I have HP Officejet 100 mobile printer. Sometimes, when I print a document that contains several pages, appears an error: While printing the printer stops operate in the middle page (for example - second page), spits out rest of the blank page and all lights starts blinking. The printer doesn't respond any action, only hard reset (unplug battery). After that, it goes normally for a several days and suddenly same behavior, same error. Printer is conected via Bluetooth. It gets these events: 69556: event_dirty_power_up 69552: event_log_no_media_pick Has anyone any idea where the problem is? Thanks for any answer.
2 Suggested Answers
6ya staff
SOURCE:
SOURCE: HP Photosmart D7360 not seen by PC, despite driver, s/w loaded
Not a solution per se - just a diagnosis. I have decided that the USB out port on the printer is bad - and after wasting time just trying to crack the case, will just use this as a photo printer "offline." It prints beautifully directly from media inserted into any of its onboard slots. I will just have to save things as .jpgs or picture formats to print from this printer. HP didn't have the part available, anyway. I called and inquired.
Posted on Jan 28, 2009
I have an orange light blinking
Unplug it, leave with no power for 15 mins, power up and update drivers from the net. Also check and replace cartridges if needed.
Jul 21, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
Take apart hp officejet 100 mobile
I dropped srews inside and need to get them out. How can I get inside?
Mar 20, 2013 | NA HP Officejet 100 Mobile Printer
Message on HP officejet 5610 All in one Error 0xd05d010d and on button,copy,fax,scan and alert yellow light keeps blinking on and off "tried reset the power cord still givwing same problem.Please help
Try to reset the printer:
Unplug the printer from power
Hold the # and 9 together while plugging it back
If still not working try again with a # and 3 combination
Oct 04, 2011 | HP Officejet 5610 All-In-One InkJet...
On-Off light on my HP J4680 Officejet All-In-One printer will not stop blinking and says "Turn power off and then on." I do that and keeps repeating the same message.
Hello.
Some suggestions from HP:
Turn off the printer, then unplug the power cord from both the printer and the wall. Wait about 5 minutes and plug it back in and turn on the printer.
Reset the printer by turning it off, hold the # and 6 keys while turning back on.
If this does not work, do a hard reset - same thing except # and 9 keys.
If this does not work, the printer needs to be serviced or replaced.
Hope this helps.
Apr 21, 2011 | HP Officejet J4680 InkJet Printer
Hello; I have an hp officejet 5610n all in one, when I turn on my printer i have this message on the printer "Error:0xd05d010d Reset power." and some buttons are blinking many thanks
lets start uninstalling your hp oj 5610 software from the uninstall program to remove it properly. Second is to install the software again... if the problem occurs the best thing to do is to go to the nearest HP Service Center in your area... i hope it helped.
Dec 22, 2010 | HP Officejet 5610 All-In-One InkJet...
I have a HP Officejet H470wbt printer ,sometimes it starts to print, and it will print about an inch or so of the invoice than stops, you have to push the resume button, then it kicks out an empty sheet.
I did what they call a power reset. If your printer is turned on, turn it off, if it is plugged in, unplug it, if it has a battery, take it off, push and hold the power button for thirty seconds, replace battery, plug it in and turn it on, wait till all the lights quit blinking and try printing, I did this and it has'nt givin me a problem since
Apr 01, 2009 | HP Officejet H470wbt InkJet Printer
HP Officejet Pro L7580 says I unplugged it, but I didn't!
It sounds like the printer is suffering from some kind of hardware failure which may have been caused by a power surge or similar.
I've never heard of this particular problem and I doubt HP will have either but my advice would be to contact HP support and see if they can provide more information or advise you better.
Unfortunately if my guess is right, there's really not a lot you can do except replace the printer with a new one.
Mar 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Need resetting
hello,
To do Hard Reset on the printer press / hold the clear button down then press the power button until the panel blinks.
Hope this initial info helps
Sep 12, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 100 Mobile Inkjet Printer, Bluetooth-Enabled Logo
64 people viewed this question
Ekse
Thomas F. Schneider
