Keurig Special Edition B60: How to clean inside:
Hello.. There are a lot of different cleaning methods and solvents to clean the insides of your Keurig coffee machine, however I don't recommend them. After using, you will still dispense remnants of whatever is leftover in your drinks, this includes Vinegar methods.. nobody likes drinking vinegar coffee.
The Dirty Truth Why You Need to Descale
I recommend using a food product that cleans effectively, called Citric Acid.. You can get this at most grocery stores for a reasonable price. You only need a small amount for each cleansing, so whatever amount you get, it will last a very long time.
I recommend the smallest package you can buy at your local store. I bought a large bag on Amazon the first time I found out about this remedy. Now, I have more than enough for a lifetime of uses.
The first time I descaled using Keurig's recommended descaler. One bottle for one use cost $18 at Target/Walmart.. I'm never doing that again.. It says on the bottle to select the highest cup size, so with the Citric Acid I would do the same. use either the rinse/brew button, dispense a couple tanks worth until it comes out clear (my Keurig machine has 5 x 12oz cups worth per tank)..
Video Tutorial:
