Hi, I have a Neff American Side by side. It is fitted with the Bosch Style Ice Maker. New in 2008. K3970x6/05. Yesterday I went to get Ice. The Ogre was jammed, tryed twice. Ice froze into solid block. Up until then I hadn't known you could remove the tray. Defrosted tray, cleaned out and replaced. Cycling fine. The tray dispensed a solid block of ice cubes, filled with water and everything seemed fine. Problem now is machine cycles fine, but will not eject ice from the tray, just keeps filling and filling with water every cycle. First thought would be tray heater, have taken ice maker apart, everything looks fine. Problem is it would be a coincidence for heater to fail at the same time the bucket freezes solid? Thinking the Ogre jamming might have damaged main circuit board. Suppose I need to test tray heater for continuity?
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
SOURCE: ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
SOURCE: Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
SOURCE: Kenmore Refrigerator 106-9557612 Ice Maker won't Eject cubes
Hi caleycatz,
It sounds like you are in need of a motor module for your icemaker. This is the motor and gear that drives the icemaker prongs. The part number is
W10190935 The price is $77.59 and $6.00 shipping
I can have one of these at your door in 1-2 days, so let me know if you need one. We take Visa Mastercard and Discover. Or you can order from sears for the same price and wait 10 days.
Good luck to you and I really hope this will FixYa. Please take the time to rate me. Thanks
Mike Anerson (Owner)
Anderson Appliance Repair
(865)945-3808
[email protected]
SOURCE: ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
