IT GOES OFF WAY TOO MUCH AROUND TOWN. I HAVE SET IT ON CITY AND STILL TOO MUCH. I KNOW AUTO MUTE WOULD SOLVE A LOT OF THE PROBLEM, BUT I CAN'T SEEM TO ACTIVATE IT.
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode
Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode
Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode
City Mode
Mute Button Press and release
To Turn Auto Mute Off
X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
