SOURCE: error code 7410
Open the left side door, push in on the drum unit which is above the waste toner bottle until it clicks.
Turn printer off then on.
SOURCE: I do I clear error code c4200 in kyocera 5050
Error Code KM4050 with 4200 error code - CopyTechNet.com
www.copytechnet.com > ... > Kyocera Mita, Copystar
Jul 7, 2010 - 10 posts - ?7 authors
I guess that you already know that the C4200 is a beam detect error, and the manual ... Hi Ya, heres a bulletin for km-6030/8030 on the code C4200. ... That it shows up on the corner, it means that you must clean the laser. ... Got a KM5050, machine was FILTHY, dust,dirt everywhere. tried to phone fix the ...
Error code c5300
Apr 28, 2014
Error Code KM5050 C3300
Sep 19, 2012
Kyocera KM-4050 C6400 error codes
Jul 9, 2008
KM5050 error code CFB31. Not in manual
May 5, 2008
More results from www.copytechnet.com
Error Codes > Kyocera-Mita > KM5050 > Code C4200
www.printcopy.info/?l=en...Kyocera...KM5050&code=C4200
Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
Solutions
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
?· Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
?· When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
?· When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
?· Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
