Assuming the paddles are attached with nuts/bolts I would suggest using Locktite. If that is not an option, lock washers. If the paddles do not attach using nuts/bolts, invest in some high end epoxy.
How to fit Washing Machine Drum Paddle Lifter For all free video help on appliance Repairs visitour Video Tutorials Here's our video guide to replacing a washingmachine drum lifter. A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple. The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out. Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines. There are few types of drum lifter; drum Paddle lifters
How to fit Washing Machine Drum Paddle Lifter For all free video help on appliance Repairs visitour Video Tutorials Here's our video guide to replacing a washingmachine drum lifter. A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple. The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out. Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines. There are few types of drum lifter; drum Paddle lifters On hotpoint, creda, Ariston ,indersit and someother makes see video To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine. Huge selections of lifters are available on thewebsite DrumPaddle lifters
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing. As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
there should be a plug on the top of the agitator. pry off this cap with a screwdriver. you will see the hex nut that fastens the agitator. remove the hex nut and lift the agitator from the transmission shaft. Installation is the reverse of removal.
Here's our video guide to replacing a washingmachine drum lifter. A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple. The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out. Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines. There are few types of drum lifter; drum Paddle lifters On hotpoint, creda, Ariston ,indersit and someother makes see video To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine. Huge selections of lifters are available on thewebsite DrumPaddle lifters
