When you say the pump won't start back up, do you mean the electrical side of things and there is just no power going to the pump. Or are you saying that the pump is on but not pumping water.
I am going to think you mean the pump is on but not moving water. This is common after you clean and drain your hot tub. You have what is referred to as an airlock in your hot tub line. It is easy to remove the airlock by simply opening one of the unions near the pump. This will allow the air to release and water flow to begin again.
Make sure also that you have cleaned the hot tub filters, if they are dirty and reduce water flow that could shutdown your hot tub pump as well.
If it is the electrical side of things make sure your GFCI has not tripped and maybe you just need to reset this. If it is anything further on the electrical side make sure you involve a professional.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
You may have to change your hot tub filters as well and can find an assortment of filters here. The filters should be changed yearly, and cleaned monthly.
Hot Tub Filters
