Http://www.appliancepartspros.com/frigidaire-pan-crisper-white-240337101-ap2115848.html
Hello Christine Williamson,
From the URL (above)... you can see two parts numbers
the 240337101 is an absolute part number crossing all BRANDS that utilize this drawer... The ap2115848 is a APPLIANCEPARTSPROS number (pay no attention
parts select, repair clinic, easy appliance parts, westinghouse & sears appliance parts... can ALL use the ABSOLUTE PART NUMBER allowing you to shop around... Usually finding SEARS at the $$$$$ high end.
DO NOT Hesitate to talk to the people at BEST RATED
APPLIANCE PARTS PROS... 5 STAR Rated + great support.
I checked appliancepartspros.com (below) get crisper parts back
and noticed that several other brand refrigerators (prominantly Frigidaire, Kenmore) seem to also share these parts (not uncommon)... but when I attempted to verify the parts back to double check compatibility (you DO NOT want the wrong parts on a HOPE)...
Patience (your parts will turn up... and at a decent price).
They did not double-check... They MUST double check.
Good luck and happy hunting
http://shop.westinghouse.com./
Search Over 2 1 Million Appliance Parts
Appliance Parts 365 day returns
http://easyappliaceparts.com/
Find Your Appliance Parts
PartSelect Appliance Parts and Repair Help
http://searsapplianceparts.com/
Try the manufacturer service agent spares
try refrigeration repair shops that may have parts from wrecked fridges
try e-bay -fridge spares
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
SOURCE: Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
SOURCE: Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
SOURCE: Water on the bottom shelf of the Refridgerator
I have a whirlpool refrigerator ET21NKXJW00. Getting water in crisper drawers, under drawers, and under bottom of freezer shelf plate. Took off bottom shelf from freezer and took out all the ice. Still getting water in crisper drawers. Help!!
SOURCE: Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
