The lid lock seemed stuck so i pulled it up and now machine wont wash at all just keeps clicking looking for the lock to work, i know u can jump it by unplugging it in service panel which i have off but there r 4 wires instead of 3 red white yellow and blue, which two do i put the jump wire in ? bought in 2011 i hate this thing! grr single mom no money ;-((
SOURCE: installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
SOURCE: how do you replace left lid lock on Maytag Neptune washer
Problem may be with door switch and not the door lock. If you are able you could try to locate the switch and jump the two wires together to see if the od code goes away. Even if it works you should not leave it that way but get a new switch and replace the faulty one.
SOURCE: Hoover 700LB top loading washing machine
there should be a wiring diagram on board in an envelope or taped somewhere you can get one from sears too
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
SOURCE: washing machine
green and yellow is earth so wire the earth wire to this. brown is live in and blue is neutral in. brown/white is live out and blue/white is neutral out. usually a suppressor capacitor has a diagram printed on it
Replacing the pump on a Bosch machine, please check
this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Hi
Thanks
for using FixYa. You can try to jump start the lid switch, if after doing this
it works then it means the lid switch is bad and needs to be replaced. Please
check this video as it provides you step by step instructions that will help
you in lid lock switch replacement:
Please
revert back for more help.
Rylee
