Cars & Trucks Logo
d
david lewis Posted on Feb 01, 2016
Why can't front passenger door be opened?
Can you release it from inside. all levers and cable are attached. central locking working ok
tlware91
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Feb 01, 2016
tlware91
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
2765
Points
29
The outside handle sounds like it is no longer attached to the mechanism that allows the door to open. Take the door panel off and look inside to determine if the handle is still attached to the rods and if the rods are still attached to the lock mechanism.
1helpful
2answers
On a 2001 Ford Focus SE five speed where is the automatic door lock relay located
Sorry Andrew , no BCM on this vehicle . The Central Security Module is incharge of power door locks . Central Security Module For additional information, refer to Section 419-10 .
The central security module is equipped with a battery back-up which holds the programmed transmitter(s) memory in the event of the vehicle battery disconnection.
Principles of Operations The Door Switch Lock Function When a door lock switch is moved into the lock position or a door lock cylinder is rotated to the lock position, the door lock switch grounds the lock circuit input to the central security module. The central security module then provides 12 volts to one side of the door lock actuators contained in the door latch unit and simultaneously grounds the other side of the door lock actuators. This completes the door lock actuator circuit, causing the door lock actuators to rotate a cam assembly, which then locks the doors.
The Door Switch Unlock Function When a door lock switch is moved into the unlock position, the door lock switch grounds the unlock circuit input to the central security module. The central security module then provides 12 volts to the opposite side (relative to locking the door) of the door lock actuator(s) contained in the door latch unit and simultaneously grounds the other side of the door lock actuator(s). This completes the door lock actuator circuit, causing the door lock actuator(s) to rotate a cam assembly in the opposite direction, which then unlocks the door(s). The 12 volts which the central security module provides to the door lock actuator(s) are provided to each door lock actuator from the individual pins on the central security module connector.
Keyless Entry When a remote transmitter button is depressed, it transmits the appropriate command to the central security module as a radio frequency. The central security module receives the command from the remote transmitter through an antenna, which is incorporated in the central security module.
When the central security module receives a command from the remote transmitter, it then sends the appropriate output to control the desired devices. These outputs devices include:
  • The front and rear door lock units.
  • Central timer module (CTM).
  • The liftgate release motor.
  • The right and left side turn signal lamp(s).
The central security module sends a signal to the CTM when courtesy lamp illumination is required.
Computer Operated Locks Each front door lock actuator contains a bipolar motor that controls the lock and unlock linkage. The lock/unlock lever of both front door interior handles use linkage to actuate the lever lock switch located inside each front door lock actuator. Each lever lock switch remains in the unlock position until lock/unlock lever of the interior door handle is moved to the lock position. This action toggles the lever lock switch to the lock position. The central security module uses only one electrical input for both lever lock switches. The central security module cannot determine whether the driver or passenger door lever lock switch was actuated. Therefore, actuating the lock feature from either front door will have the same affect of locking all doors. Actuating the unlock feature will not unlock any other door.
The door lock control switches for both front doors also use only one input to the central security module.
Both rear passenger doors contain a rear door lock actuator that controls only electric lock or unlock of the door. Actuating the lock/unlock lever at either rear passenger door will have no effect on other doors.
The panic feature of the remote transmitter sounds the vehicle horn when the vehicle is not equipped with anti-theft. If the vehicle is equipped with anti-theft feature, a separate horn is sounds for the panic feature.
BMW 316i Compact 2 Door Coupe, unable to release drivers door lock with the central locking or key.
check and manually move linkage to unlock ---use a long screwdriver to move lock mechanism or if unlocked move latch to release
Central locking 2005 subaru liberty stopped working on 2 doors
1. Replace battery in remote
2. Replace sensor at rhf door lock (it is inside of door)
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
1helpful
The inside drivers door lever will not open the door, I have replaced the cable from the lever to the door lock a week ago because the cable broke. The lever worked the lock for a week and now the lock...
No idea here without removing the door panel myself to have a good look so i would suggest that as you open door from outside then it isnt the central door locking but a mechanical problem like the plastic clip has come off or wasnt fitted right and now its dropped out of the hole on the door lock mechanism
1helpful
Central locking on megane 2000
is yours the renault keycard to start and open doors?if it is a know these cards can go faulty.they were bad on renault laguna.the switch breaks off the board inside card.can be soldered back on.think you can get replacement switch kit on ebay with instructions how to fix.need someone who can solder with some eletronics knowhow.if not not sure sorry
18helpful
2answers
Central locking keeps locking the car. Unable to open drivers side door
Hello, we have a 2003 Kia Rio- problem as above- unlocking and then locking- only way in and out through passenger door.
This is what I have done and everything is back to normal- I hope it works for you.
1 Remove 25AMP fuse that controls door central locking from main box under the bonnet.
(AT this stage my passenger door opens- drivers side does not, the mechanism won't fully rotate)
2, Spray key with WD40 (or similar moisture repellent lubricant). Gently turn key to loosen mechanism- Partly remove key and spray lubricant into lock, have fun locking and unlocking!
3, Replace 25 amp fuse
4, Write yourself a cheque for garage labour and parts and wife brownie points!
20helpful
3answers
Renault Clio Rear Door Lock Fault
It has nothing to do with the "child lock" It is a know problem in this car, they tend to get caught in lock. Only thing to do, is to take of the panel then the outside handle, and through that hole destroy the plastic covering the lock, a large screwdriver and hammer will do! Then you can release the lock, while you pull the inside release handle. Buy new!
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
