Maytag MDE2400AYW Neptune Electric Dryer Logo
Tina Stitzel Posted on Feb 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Maytag Commercial electric dryer in my home ,brand new sat for 2 yrs,got it to work 3 times,then quit.Computer panel was bad,replaced it,the model # is MDE22PRBYW0 not what's showing above
I changed out the computer board,and now i'm getting an error code d5,according to my book it says this means blocked coin 1 or coin drop UI control circuit failure.I don't even have the coin part with my dryer,i use it in my home...Help !!
David Ellis Rhea
Level 3:
  • Maytag Master 3,462 Answers
  • Posted on Feb 01, 2016
David Ellis Rhea
Maytag Master
Level 3:
Answers
3462
Questions
Helped
784855
Points
10903
So then, you have purchased a computer panel that is designed for a "pay" machine., or perhaps for another model than you have.
(In that case, the "d5" would mean something else.)
Please look at "Sears Parts Direct" on your computer and see what they say as to your replacement panel part number.
What I do is then go to e-bay and search the part after I get the correct number.
I surely hope Sears will have the schematic for your machine.
God bless your efforts.
  • Tina Stitzel
    Tina Stitzel Feb 02, 2016
    thank you for the response,much appreciated,i am on hold with Sears as we speak...
1helpful
No power with maytag neptune dryer, how to change fuse
be very careful with electricity. fuses are in the home's wiring. open the dryer door. if possible follow the wire
from the large plug back to the home's main electrical panel. there may be a small panel just for the dryer or it may be connected directly into the main panel. locate the fuses if used, unscrew them and replace them with ones you know are good or use an electrical meter to test the original fuses for continuity. install good fuses.
if your system uses circuit breakers, locate the breakers and look to see if they have been moved from the on position. switch them off and on a few times and leave them on. go and close the dryer door and choose a new dryer setting to try to see if your dryer works. great if all works as it should. if dryer won't start or fails again, you need to have your house wiring inspected or your dryer repaired. call for help without delay.
MAYTAG GAS DRYER NOT HEATING
That sounds to me like you need to replace the coils. They get intermittent with age. Work some then quit take a long time to cool down and work a little more when going bad.
MY MAYTAG DRYER HOME REPAIR VIDS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Brand new dryer is working but noisy
Aha: slope front dryer. Could very well be something down in the blower housing making the noise. To get into these you remove the door then the front panel comes off then the top can be raised so that you can get the front shroud off there to get the drum out. You cannot work from the back of this dryer. I have an older slopefront dryer service manual
1helpful
2answers
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Maytag Dryer
hi thanks for the question i would check the venting on this dryer make sure its clean if you can vacuum the entire dryer this will solve your problem thanks the appliance doc
Neptune dryer will not work
PF= Power failure hit the cancel button and it should clear then you will be able to select a cycle. Let me know
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
