This is the explaining right from sears for code DE
Door is open error
Check/Repair
Unplug the washer. Check the door for an obstruction. If the door is damaged, replace any defective parts. If the door is closing properly, check the door lock/switch assembly wiring. If the wiring connections are okay, then you will usually need to replace the door lock/switch assembly.
Shop Parts
Door lock/switch assembly, Washer door components
