SOURCE: Sanyo DVR-DX600 Region Code
Could you pls try:
1. Remove DVD or video from the player.
2. Press the ‘Set-up’ button on the remote control.
3. Select the ‘System Info’ mode from the on-screen menu.
4. Using the remote control 10-key type in ‘1101′
5. ‘Region code’ should appear as an option on the ‘System Info’ menu. Initially the region code will be set to 2. Press ‘0′ on your remote control using the 10-keys to set to multi-region.
6. Press ‘OK/Enter’ on the remote control.
7. Finish by pressing the ‘Set-up’ button once more.
This was actually intended for a Sanyo DVR-V100E &HVRDX610 but I was made to understand should also work for DVR-DX600. This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: My Sanyo DWM-400 plays some DVD's and won't play others.
I bought another DVD player. I found out that all DVD's don't play on all DVD brands of players. They are cheap enough these days so I decided it wasn't worth a repair bill. The Sanyo DWM-400 plays many of my store bought DVD's and not others. I never tried a home made DVD in it so I don't know how it responds.
SOURCE: cant get rid of closed captions on dvd player
go to menu turn off captions thank you for using fixya
