2005 Nissan Murano Logo
Alison Hughes Posted on Feb 03, 2016
How to enter a radio code - 2005 Nissan Murano
Steve Morris
Level 1:
  • Contributor 26 Answers
  • Posted on Feb 03, 2016
Steve Morris
Contributor
Level 1:
Answers
26
Questions
0
Helped
28267
Points
54
4 digit code can only be entered when 4 dashes appear
Or ----
To enter code 1134
Button 1 = first digit of code press once =1
Button 2 = 2nd digit of code press once = 1
Button 3 = 3rd digit of code press 3 times =3
Button 4 = 4th digit of code press 4 times = 4
Press and hold AS button until radio activates
How do I unlock my radio on an 2016 Chevy equinox
Step 1: Look at your radio. Check and see if the code "RDS" is written on the face of the radio. If "RDS" is present, contact a GM dealership to have your radio unlocked by them.
Step 2: Check for the identification code. Press buttons 2 and 3 for 8-10 seconds. If a code does not appear on the display, you won't be able to unlock your radio in this manner.
[If that doesn't work vvv]
In order to obtain your radio unlock code, you need to find your radio's serial number. You can get the radio serial number directly from your radio.
Step 1: Turn on the ignition. Turn the key to "accessory" mode or "on" mode.
Step 2: Turn on the radio. Press the power button to turn on the radio.
If your radio displays any functions such as playing a CD, cassette, or a radio station, your radio is not locked. If no sound is heard, you may need to replace your radio unit.
If your radio is locked, "LOC" is displayed on the screen.
If "INOP" is displayed, keep your ignition on for 60 minutes with "INOP" on the display. After the hour is up, it should change to "LOC." After this you can proceed with the next step.
Step 3: Write down the code. Press buttons 2 and 3 at the same time and hold for 8-10 seconds. Write down the three-digit code that is displayed.
Step 4: Note down the code. Immediately press the AM/FM button. Another three-digit code is displayed. Write it down as well.
This is your six-digit radio serial number.
Now that you have your radio's serial number, you can obtain the radio unlock code from General Motors. Be ready with a pen and paper to write down your radio unlock code.
Step 1: Contact the GM radio hotline. From any landline or cell phone, call the toll-free GM Radio hotline at 1(800) 537-5140.
Step 2: Enter the code. When it requests a code, enter "106010" on the keypad, followed by the pound (#) sign.
Step 3: Enter the radio serial number. You will be prompted to enter the radio serial number you have just obtained.
At the prompt, enter the number followed by the pound sign.
Step 4: Write down the radio unlock code. The prompt will read out your four-digit radio unlock code. Write it down precisely.
Now that you've obtained your Chevrolet radio unlock code, you need to enter it into your radio.
Step 1: Switch on the radio. Turn your ignition on and press the radio power button. Your radio will display "LOC."
Step 2: Enter the first two digits of the radio unlock code. Press the hour button on the radio to enter the first two numbers of your radio unlock code.
Continue pressing the button repeatedly until the first two digits of the radio unlock code are displayed.
Step 3: Enter the last two digits of the unlock code. Press the minute button until the last two numbers of the radio unlock code are displayed.
Repeatedly press until they match the two digits you need.
Step 4: Confirm the code. When the code matches, press the AM/FM button. "SEC" will display on the radio, indicating a successful attempt to enter your radio code.
If you enter the code incorrectly eight times, the display will switch from "LOC" to "INOP." You'll need to leave the ignition on for an hour as described in Part 2 before you can retry.
Write the radio unlock code in a safe place such as in your owner's manual for future use.
Most car dealers will charge you a lot of money just to get the code for you. If you follow the right steps, you can get the code for free and be able to start listening to the radio again in just a few minutes!
How to Unlock Chevrolet Theftlock Radio
2answers
My actros radio blocked by entering wrong code . now i know the code but how to remove the message blocked and to write the correct code?
I don't know the radio brand. But generally, some radios are blocked for some time after entering a wrong code. Entering next wrong codes multiplies blocking time. Try to have switched on the blocked radio for longer time, it may offer entering another code. It is a good idea to find out the way how to enter the code before its entering. Sometimes it is quite tricky.
1helpful
How can I enter radio code?
Use the radio station preset buttons to enter the code after you turn on the power to the radio. The radio's display may say "CODE" asking for the security code.
2helpful
How to insert the code for the radio of my golf3 /1996
ENTERING SECURITY CODE
Most vehicles are equipped with Heidelberg V or VI radios that are equipped with a theft protection program. When the battery has been is disconnected or if the radio has been removed, the radio will lock-up electronically and cannot be operated until the security code is entered. On the Heidelberg V, if the proper code is not entered in six attempts, the radio will lock-up permanently and cannot be repaired. On the Heidelberg VI, two incorrect attempts will lock the radio for about 1 hour.
The Heidelberg V may have a code assigned at the factory or a personal code created by the owner. The Hiedelberg VI has a code assigned at the factory and entered by the dealer during pre-delivery inspection. New radios come with the code printed on a sticker but not entered into memory. All codes are 4 digits. To code the radio:
Heidelberg V
  1. Turn the radio ON . The radio should display the word SAF. DO NOT attempt to eject a cassette with the radio in this mode.
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear for about 3 seconds, then the display will go blank. Release the buttons then.
NOTE If the buttons are held too long, the radio will interpret this as an attempt to enter an incorrect code.
  1. Use the first four station selector buttons to enter the code. The first digit of the code is always 1. Each time the other buttons are pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When the radio plays and displays a frequency, release the buttons.
  3. If the code was entered incorrectly three times, momentarily disconnect the battery and try again. If the code is entered incorrectly three more times, the radio cannot be coded and cannot be repaired.
Heidelberg VI
  2. Push the AM/FM and SCAN buttons at the same time and hold them until the display changes, then release them immediately. The number 1000 will appear and remain in the display.
  1. Use the first four station selector buttons to enter the code. Each time a button is pushed, the number in that position will change.
  2. When the code appears correctly in the display, push the AM/FM and SCAN buttons at the same time. When SAF appears in the display, release the buttons. The radio should play and display a frequency.
  3. If the code was entered incorrectly two times, leave the radio ON for one hour and try again. This can be repeated as often as required.
5helpful
2answers
I need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
  1. If the radio is disconnected from the power supply, it is not operational when re-connected. After switching on the ignition and the radio, the readout CODE appears in the display.
  2. The code number for the radio is advised to you on the enclosed CODE CARD.
  3. To enter the first digit of the code number, you have to continue pressing station button 1 until the correct digit appears in the display. Adopt the same procedure for the second, third and fourth digits.
  4. Once you have entered the correct code number with the station buttons 1, 2, 3, 4 and confirmed the entry with the SEEK button (press down), the readout CODE disappears. The radio can now be operated.
  5. If you enter a wrong code three times, you must wait 15 minutes before making a new entry. In addition, if 9 incorrect entries are made, the radio will then not operate for 24 hours. During this time the radio and the ignition (terminal 15) must remain switched on.
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
  1. If the radio is disconnected from the power supply, it cannot be operated by simply reconnecting. After switching on the ignition and the radio the word "CODE" appears in the display on the radio.
  2. The code number for the radio is given on the enclosed CODE CARD.
  3. Enter the code number with the station button, e.g. number 1, station button 1. After entering the first number the word "CODE" disappears and the number entered appears followed by 4 dashes. The next character to be entered flashes. After entering all five numbers, the first character starts flashing again. In this state the code number can be written over as frequently as desired. A correction can be made only by entering the complete code number again.
  4. Confirm code number: Press TUNE, AUTO/SEEK or SC button. The radio automatically switches on and indicates the radio station or frequency stored with station button 1.
  5. If an incorrect code number is entered and confirmed, the word "CODE" appears again on the display. If an incorrect code is entered three times the word "WAIT" appears on the display and the radio locks up for approx. 10 min. If the code is entered incorrectly three times again the radio locks up again for 10 min. Three more incorrect entries (a total of 9 incorrect attempts) increase the lock-up time to 60 min. Another three incorrect entries lock up the radio for another 60 min. The waiting time runs only when the radio is switched on.
6helpful
3answers
2001 mitsubsi eclipse enter car radio wrong code 3 times
call 1888mitsu2001, choose option #4, then hit * (star). give the operator the last 8 numbers in your vin and they will provide the radio code for FREE!
DO NOT PAY FOR THE CODE ONLINE OR GO TO THE DEALER (they will also charge you).
- you will also need to provide the serial and part number of your radio (takes about 5 minutes to take apart an eclipse dash...1 screw in the bottom of the HVAC panel) if you call the 1888mitsu2001 it will provide basic instructions on how to accomplish this.
- if your radio says "off" (meaning you entered the wrong code too many times) you need to put your key in the ignition and turn it to ACC mode for approx. 45min - 1hr and then your radio will say "code" at which point you can enter the code to unlock the radio.
2answers
How do you enter the code in the radio to turn it back on.
Take the batts cable off an hold them together for 10 sec an that reset the compute your radio will read enter code
4helpful
5answers
Radio code
i need the radio code for my honda accord
1helpful
Radio code
turn on the key
the radio will say code
just start entering the code via the preset numbers.
When the correct code is entered the radio will switch from displaying code to the normal display.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
