Question about Sony KLV-37S400A 37 inch Multi-System HDTV LCD TV
TV dead. How can i fix this without replacing the whole board?
I have checked the input AC volts all is well, i am not getting the 3.3V in the secondary to switch the supply on.
    Social Butterfly:
    An expert who has shared 10 answers on their Facebook wall.
  • 166 Answers
You can try the troubleshooting section of the manual here: http://www.manualslib.com/manual/440142/Sony-Klv-32s400a-32-Lcd-Tv.html?page=36#manual
Posted on Feb 04, 2016
6ya staff
SOURCE:
Model Yamaha ME-50 no power
John
With AC power off.
Use a meter (on Ohms scale) to check internal fuse for blown (open) fuse.
If you feel qualified & safe with AC Power On.
Check input to internal power supply on AC Scale (Caution when AC is on) for volts in.
Use meter on internal Power Supply for "probably" DC volts leaving internal Power Supply electronics to power the rest of the electronic circuits.
Switch mode power supplies can break down. They stop doing their high frequency switching so they don't convert AC to DC.
If this P/Sup is a separate box or circuit board, inside the unit, then it can have a part number & be replaced.
Good Luck
Jul 14, 2014 | Yamaha Music
How do i build a 12vac 2a adapter step by step.
Just get a transformer with a 12 volt 25 VoltAmp rating on the secondary and a primary suitable to your mains power in your part of the world. 120 VAC 60Hz for continental North America. for example.
Put a power cord on the primary with a suitable switch to shut it off, and the output of the transformer will provide you with the 12 Volts AC at 2 Amps output. Attatch the suitable adapter to the end of the secondary wires, and you are all set. AC does not have a polarity like DC.
Dec 22, 2011 | Computers & Internet
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
I have a Behringer xenyx 802 audio mixer and have lost the power supply. I tried to buy a replacement, but cannot find any in stock. I'm very resourceful and thought I'd make one. The spec sheet calls for...
No, you can't just jump the pins together. The power supply in the mixer needs two separate 18-volt AC inputs because it makes two supply voltages, +15 and -15 volts.
The external supply is just a potted 36-volt transformer with a center-tapped secondary. I bought an open-box Behringer (not your model, but similar) that was missing its supply, and found this transformer which works fine. (I actually did find a couple of sources for a replacement Behringer supply, but it cost more than I paid for the mixer!) Just connect the three output leads to the appropriate places on the mixer's PC board. In mine, I removed the original input connector and soldered a pigtail with a 3-pin connector from Radio Shack to the PC lands, then attached the matching plug to the transformer leads. You'll also need to provide an enclosure of some kind to prevent contact with the line voltage input to the transformer and to protect the thing if you carry it around.
Mar 29, 2011 | Audio Players & Recorders
Model 27LCDB03B-simply appears to be "dead" won't power up-not the fuse
Hello Chris, Hi, your TV's power supply section is not functioning properly. If the fuse is in good shape, then the auxiliary power section of the power supply is not functioning, this section powers the switching oscillator and IC that sends the pulse to the switching element like power transistors to create a main secondary voltage. the main secondary voltage is the circuit that produces all voltage needed source by the TV. what you can do if you are up to it.
A. Visualize any bulging capacitors, replace them. B. Measure the voltage across the following section in particular order so we can find the faulty parts.
  1. the AC input on the Power supply board. (none means open switch or power cable)
  2. the AC after the line filter circuit. (none means open line filter)
  3. the DC on the filter capacitor. (none means problem on the rectifier)
  4. then the AC on the switching element or input on the main transformer. (most likely you won't have any voltage reading hear.)if you do have continue.... (none means you scratch your head, this is the hardest part) check all low value resistors, high wattage resistors open or shorted diodes.
  5. the dc on the secondary filter capacitors.
If not have this checked by a technician, its to complicated for you.
Mar 12, 2011 | Thomson Televison & Video
Power supply circuit boards,gives only 2.0 volts
OK, what is the input voltage? I will give you a ruff diagram here. (volt in) Vcc--sw's-on/off/IR-control board (microprocessor)---ccfl (cold cathode fluorescent lamp) inverter (changes DC voltage tow switching DC (such as on/off/on/off/on/off but at a much faster pace (20Khz)---toroidal coil (this coil will step the switch DC voltage up to about 1000 to 1500 switch DC volt, then this coil will change the orientation of the voltage to current relationship by shifting the current by 90 degree's where it lag the voltage---this process has some changes on circuit and how it works)----OK, from the ccfl inverter------voltage multiplier (all this some HV capacitors and HV diodes hook up an configuration where each stage will double the voltage that go into... EXAMPLE: 4 stage voltage multiplier for each stage now it double the voltage 1500V input to 1st stage--output to 2nd stage 3000V output to 3rd stage 6000V out put to 4th stage 12000V switching DC, they will also refer to this voltage AC voltage because AC switch to from - negative voltage to + positive voltage.
Like in you case, the two volts from the controller to ccfl. Out put volt from ccfl with be around 2.4 to 2.6 due capacitance discharge, Now this voltage will be divided in the ccfl by two input windings (I am not going to explain this). Now the two input winding will induce voltage to the secondary winding (step up). The output from secondary of toroidal coil will be multi switching to the voltage multiplier. Probably in the neighborhood of 1500 switching volt. How many stages the voltage multiplier has I don't know. The ignitier voltage to the cathode from the multiplier would be around 12000 voltage to get image intensifier tube to fire. stewbison
Feb 09, 2011 | Quest ITT Night PVS-14 Gen 3 Night Vision...
I live in New Zealand which has 240 volt supply on the grid. The zantrex 2000 works with an input supply of 120 volts. How can I use it?
Hi, OK, there are two ways to achieve this. One. Using an external STEP DOWN Transformer, 240 V AC, to 120 V AC. The ONLY thing that matters is KVA. As long as the KVA is the same ir will work. This means as long as the Output Voltage and Current are the same, it's irrelevant whats on the Secondary. So if
The second, is to remove the existing transformer, and substitute with an exactly the same Secondary Outputs, BUT with a 240 V AC,. Input winding. Most likely it is a simple step Down transformer anyway, that steps down, whatever the external voltage is, down to say 12 -18 V AC. Therefor ANY suitable 240 V AC transformer with the SAME secondary winding(s) will work, no problems. You can even get some transformers Overwound, for 240 V AC, a very common thing, depending on transformer construction. There are a few transformer manufacturers in the "Yellow Pages" contact one of them and inquire.
As a tip, sometimes the existing transformer has TWO 120 V windings, and sometimes only ONE side is used, for US power, and for 240 V AC, you simply connect the other winding in series, and NOW you have got your 240 V AC to whatever.
Sep 01, 2010 | Inverter Xantrex MS2000 Sine Wave Charger...
Powerunit demaged, mising -12V, 12v, 5VAD not missing -28v, u5V Where is the problem
check primary of thransformer AC mains volts, then
check secondary of transformer AC low volts into each rectifier then check DC volts at capacitors then check DC volts at regulators inputs then check Dc volts at outputs
as you go draw cct diag and layout so you know where everything is and how it is connected.
if its the psu you will find the fault, only ever replace items with original parts or direct equivalents.
Hope this helps
Thanks for using FixYa
Aug 12, 2010 | Audio Players & Recorders
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
Aug 26, 2009 | Audio Players & Recorders
Where to hook up com neg. lead to check dc volts on tv????
Most TVs today use a "hot-chassis" design and a switch-mode power supply. You should use an isolation transformer when doing any service work on a TV. This helps protect you and your test equipment, and can prevent accidental damage to the TV by grounding parts to the wrong point.
Hot-chassis sets use two different grounds. The power supplies have one ground reference for the primary side (hot ground) and a different point for the secondary (cold ground). The point you pick will depend on what part of the TV you're measuring.
If you are troubleshooting a dead set and working on the primary side of the power supply, use the negative lead of the large electrolytic capacitor you'll find near the AC input connection. There's almost always a bridge rectifier and filter cap (300 to 400 uF range, 180 to 250 volt rating, so physically pretty large) in that area to make the raw DC. That's a guaranteed good hot ground. Sometimes the set will have a labeled hot ground point right on the circuit board for you.
For measurements on the secondary (output) side of the supply, almost any shield can is ground. The tuner cover is a good choice.
Jan 29, 2009 | Sanyo DS25390 TV
Sony KLV-37S400A 37 inch Multi-System HDTV LCD TV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
