SOURCE: Ricoh FT 6665 copier
Zero Cross Signal Malfunction.
Fusing/Hot roller temperature does not increase.
The fuser rollers need to be inspected.
SOURCE: ricoh color copier service code
Hello sir; Let's try to reset;
1, press "clear mode", "107", then press and hold down "clear/stop" for about 3 second.
2, touch copier SP,
3, enter SP5-810-2 pres enter.
4, press 1, then turn power off and back on .
SOURCE: ricoh copier model LD060 service code 550
if the cleaning web in the fuser is at the end the sc550 will apear you will have to replace and then reset the counters for this in the sp mode 7 data log the web drive motor time and coverage
SOURCE: My church has a FT4022N Ricoh copier. Need
Look for a Ricoh or Savin dealer. They should be able to help you. This machine is old, so don't get your hopes up.
SOURCE: how to reset routine service required and change
service mode F7 26 set web to 120,000, need more info contact me at [email protected]
Hi KING FAHD SCHOOL, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
