Okay so yesterday my phone was charging perfectly fine and i took it off the charger and now it doesnt not want to charge it says its charging but doesnt go past 2 percent what do i do ?
I plug the charger up it says its charging then dies and it was perfectly fine the day before ive tried 2 differnt chargers what do i do to get the phone to charge please help
There are 3 possible causes of the problem that need to be checked. The phone, the battery and the charger.
Try to insert another battery into the phone and try to charge with another charger, if it charges, the phone is okay, if it does not charge, then it means the phones connection/ charging port is bad and need to be replaced.
Test the battery in another phone and try to charge to see if it will charge, if it does not charge, then the battery is faulty and need to be replaced. But if it charges, then the battery is okay.
Finally check the charger by trying it out on another phone to see if it will charge, if it charges, then it is okay, but if it does not, then it means the charger is bad and need to be replaced.
After carrying out these tests, you would be able to detect the problem and know the best part to be replaced.
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
This happened to me too, you have to take your phone back to who you bought it from so they can repair it. Its the chip inside the phone that is bad. Not the charger.
Phone not charging. Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Hello ! I'm not sure if this solution is helpful, but I know 3 ways to charge it. You can charge the phone by using the charger provided in the package; you just leave the phone until it says something that means its charged full, or fully chargedXD. Umm, if you use the usb, it doesnt mean you have to use the syncing program, you justt connect it to your pc and leave it, thats what i'm doing right now, lol :P third way, you can charge it in a car using phone charger made to charge from a car. If this doesnt help, sorry! But maybe you should go check and ask about the people who sold you the phone or it could be the battery problem in your phone! Good luck thought :)
