Question about Universal Televison & Video
Trying to match up a triantianyong TV-139F universal tv remote to this LCD TV DVD combo.
Remote uses a 3 digit code. Tried several dozen suggested codes with no luck. Help?
    Top Expert:
  • Universal Master
  • 9,098 Answers
Search Results
    Universal Remote Controls - Encompass Parts
    https://www.encompassparts.com/staticlist/Universal_Remote_Controls
    TVs made since 1988. Works Mitsibushi . TVs only. Will not operate. TV/VCR or DVD Combo units. ... fully operate yout TV. Full function replacement remote for ToshibaTVs made since 1988. ... 2004-2005 LCD TV's. ON/OFF, CHANNEL +/-, ...
    Universal TV Remote ' eBay
    www.ebay.com/bhp/universal-tv-remote
    eBayUniversal Remote Controller 6 IN 1 TV DVD VCR Satellite Receiver Cable Box Audio... control for Samsung LED/LCD TV is the lastest product, easy to operate and ...damaged or needs to be substituted, or when you dxxire to have a combi.
    Codes For Universal Remotes ' Universal Remote Control ...
    codesforuniversalremotes.com/
Posted on Feb 05, 2016
6ya staff
SOURCE:
Need Comcast 5-digit universal remote code for Sony BDP-S3100
Find Your Comcast Remote Control Programming Code
make sure your using those codes with the AUX button. Comcast does not have all remote codes for every electronic made though.
Feb 05, 2014 | Comcast Custom DVR 3 Device Universal...
I bought a Radio Shack universal remote. It does not list Element codes. I've done the suggestions but it doesn't work. What are Element's codes??
hello!
"Element" codes could be: Polaroid, MAG, LG, Vizio.
Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
Sharper Image jumbo remote will not accept codes
Your best bet is to use the auto-search function of the remote to run through all the choices in the SAT category for the Direct TV box. I know it is more of a cable box, than a satellite box, but there are many code choices for direct TV under the satellite code listings. I think you will be out of luck for the Bose Cinewave. I am surprised that the Panasonic TV codes didn't work for you using the auto-search.
Here are the codes I have handy for Direct TV set-top boxes (SAT button) : 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216 & 217.
And for Panasonic TV's: 003, 054, 055, 062, 070, 148, 170 & 171.
And for Sony DVD's: 009 & 174.
To program your remote to the TV by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
As I mentioned, try substituting SAT for the Direct TV box, and of course DVD for the Sony player.
I hope that helps.
Dec 31, 2009 | Innovage Jumbo Remote Control
Codes for scientific atlantic cable box
That TV needs a 4 code remote.
Mine uses code 1702 on a Phillips SRU2103/27 I got from Sears for under $10.
Joe
Dec 15, 2009 | Vizio L32 32 in. LCD HDTV
Still can't find a code for Electron LCDTV
You have joined the ranks of those who have several 'universal' remotes. They aren't. They are, at best, multidevice or multibrand remotes and even the 'learning' remotes don't learn from some originals. The use of the word 'universal' is a fraudulent nomenclature.
In looking at the product description, I noticed this:
"The DRC450 remote control is designed specifically to work with all Motorola and General Instrument Digital Cable Terminals."
It was then never designed to handle any updating.
You might try to obtain newer codes from the Motorola site for your model:
Motorola DRC-450
I didn't see any provisions for updating the code set via computer so it will likely never do what you want.
Jul 06, 2009 | Logitech Harmony 550 Remote Control
Remote codes
unfortunately if you've tried manual codes and auto search it's most likely a compatibility issue. there is a website called remotecentral.com that sometimes has additional codes. also option of getting higher end remote such as marantz which would have higher end capability for programming external devices
Aug 16, 2008 | Televison & Video
Need ESA code to program our Zenith Universal remote 425
I own a One-for-All universal remote (model URC-4220) , and my booklet says the setup code for an ESA TV ( without a built-in DVD or VCR) is 0171 or 0812. I can not guarantee these numbers will work with your remote, but it is worth a try.
The alternative choice, is to purchase the same remote that I have, which cost less than 10 dollars at Walmart.
Jul 08, 2008 | ESA EF402E 20" TV
Remote code for Hyundai Q320 TV
como funciona un control remoto universal para un tv hyundai
Feb 29, 2008 | Sony RM-V310 Remote Control
Televison & Video Logo
364 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
