Yes the T-con board is down. You or a service person in a TV shop can fix this. The problem on the T-con is located as F100. Replace the fuse. It is located next to the ribbon on the bottom right. This service mount fuse is rated at 3.15 amps. Mouser Electronics has this part #576-04583.15DR. You want to repair this. Ohhh, the T-con is a small board the size of an index card. It may be covered, under a shiny plate, near top center I think. You have the repair. Thanks for asking, Matt of Martins TV.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in "T Con board" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
