HI, you have to refer to your manual to avoid confusions and damage from any advise here. Or go to the store where you purchased that for after sales support. Even if I know the answer I would still refue to answer due to incompatible answers.
Sorry that keypad is no used to u.If u don't know the secret codes.Just push in the codes it will work.No enter button,mean u just don't push enter after u push in the codes.
inside or on the back of the opener motor housing or sometimes on a remote receiver (an external box connected to the motor unit and a push button) is a set of switches ... if you take your opener apart you should also see a set of switches ... those have to be set the same way as the opener ... thats the code select ... make sure the battery is ok .. you can check with sears to see if your older remote is compatable ..
Find the smart/learn button on the rear of the motor unit just to the left of all those white wires. Press and immediately release this and then walk over to your keypad and key in any 4 digit PIN you like and press enter.
Press and immediately release the learn button and then walk over and key in your 4 digit PIN and press enter. If your opener is older and the keypad is the new generation it may not be compatible with your opener. You need to make sure you take the model number off the motor unit when you order new parts or accessories. The model number starts with 139.
The problem is: The antenna(s) on the body of the radio are missing. Would like to know where they can be purchased. Not a rocket science question. Any assistance would be appreciated.
Yeh, it is called reading the manual. Push and hold LEARN or SMART button for 10 seconds, Release, Push for 1 second and enter keypad code and ENTER, Kight bulbs should blink. Hit learn again for a second and push a button on a remote. Repeat for all remotes.
