The comm error 252 occurs due to,
This error can be rectified by
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Hi
HP error code 252 means.. . 252 Telephone line conditions were too poor to receive a fax.
*Reattempt the fax reception at a later time when line conditions may have improved.
*Configure the machine to start reception at a lower speed. *If the local machine received several pages of a larger document successfully, ask the remote user to transmit the document in several smaller parts.
do let me kno ,for further clarification
all the best
regards
hi
all the best
regards
How to Configure the machine to start reception at a lower speed.
SOURCE: hp laserject 3015 comm error 252
It is most probably the problem with line. Try to call from you fax machine and check the line condition.
SOURCE: We are having lots of problems receiving faxes.
There is a big chance this is a line problem, contact your phone line company before trying to fix or replace your Fax modem on the MFP.
Good Luck
SOURCE: i am not receiving faxes,
Hi
Turn off your printer and remove the ethernet cable connecting to your printer for2-3 minutes. Then try to plug the ethernet cable or usb cable into the computer.
Try also to download this software http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xerox-and-everything-else/. Download, unzip and install it to your computer. Just click on the blue name of PRINT DIAGNOSTIC UTILITY. It will helps you find the errors in your printer and fix errors in just a second.
I am sure it will helps you solve your problem.
