SOURCE: HP tablet PC tc4200 latch fixable?
In a pinch, you can pop the lid open on these by sliding a credit card between the screen and base chassis. Typically when the latch breaks on a tc4200/4400 it will need to be replaced unless it is simply jammed.
SOURCE: I am having a problem with a broken screen on my
you can replace the glass by taking it too the nearest glass store as long as the screen still works
You need to buy a new screen an have it installed. If you are not an electronic technician, don't try to do it yourself.
SOURCE: I fix the broken screen on my RCA tablet and now my Wi-Fi won't work.
Droid Pro: wifi won't turn on - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Motorola Droid Pro
Dec 17, 2012 - 25 posts - ?23 authors
Ok so I tried to turn on my WiFi in the settings and it would say turning on ... myphone, done a factory reset and even used a WiFi fixing app. ... wifi fixer doesn'twork. ... to lock my phone without the screen staying on for 15 seconds or so. ... I was having trouble turning on wifi on my tablet and one of the post ...
Auto Rotate does not work.
May 11, 2014
New Tablet/Authentication Problem with Wifi
Dec 17, 2013
WiFi stuck "turning on"
Aug 18, 2013
More results from forums.androidcentral.com
Android Tablets Forum - Tom's Guide
