Makes a beeping sound but does not turn on. The oven is fine and I have tried turning off at teh mains and resetting the clock.
SOURCE: brand new bosch pke691e20e ceramic hob trips 50amp mcb
You have a short to ground somewhere.
Was there a new cord installed on it or did the cord come already installed?
It could have been wired wrong causing a short to ground. there could be another wire touching the cabinet, a wire pinched by the cabinet.
You may have to trace down every wire with a continuity meter to find it, but its probably fairly obviose.
I'd start at the cord.
First try this, unplug the cord, turn the breaker back on just to make sure the problem is indeed in the unit not the receptacle or panel box.
If the breaker stays on, you know its in the unit.
