Hi, you need to perform a factory reset, follow these instructions:
Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
"Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
Use the volume buttons to move up and down through selection in this menu.
Using the volume down button, scroll down to "Wipe data/factory reset"
Tap Power hard key to select option.
Scroll down to select "Yes, delete all user data".
Tap the power button to select. Wiping and formatting data will take a few minutes.
You will return back to the Android recovery screen menu.
Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
I had this similar tablet...it quit on me after 2 months. I called the company and they replaced it with a M9200 which would not turn on after 1 month. I found the factory reset button on the back under a small sticker. Plug it into the charger and gently push a sharp toothpick or other sharp non metallic object inthe the small hole until you get resistance. Then gently push 'till you feel a tiny click...this should reset the tablet. Mine crapped out because it is a junk company. There are more complaints on this company than any other I have ever seen. I wised up and bought Google Nexus 7...best 7" tablet made.
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds.
Debugging mode has to be engaged by running ADB, but becomes quite complex and device specific. Plus it can stop your tablet from working all together, so try this first.
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
You maybe able to RESET the tablet. There maybe a pinhole RESET button on the back of the tablet. Insert a straighten paper clip into the pinhole RESET button to reset the tablet.
ANDROID Tablet Freezes at Android startup screen For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button 2. When "VIMICRO" appears, Then Press & Hold the MENU button 3. The Android System Recovery <3e> Menu should appear 4. Scroll down using the Volume Key to "wipe data/factory reset" 5. Press HOME Button 6. Scroll down to "Yes - delete all user data" 7. Press the HOME Button At this point the system will do a recovery and hard start, and will be on "reboot system now 8.Press the HOME Button Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
