Lands Phones Logo
Anonymous Posted on Mar 31, 2017
Why aren't BT master socket extensions working?
BT installed a fibre optic modem to a telephne extension outlet using a BT Master socket. The modem works fine and I connected a 3rd party WiFi transmitter/receiver. Again good connectivity throughout the house. Also, the telephone plugged into the BT master socket works fine. BUT - no other ongoing telephone extensions work at all! I tried talking to BT but they were useless - said the problem was with the extensions. I responed that the extensions worked fine before BT installed the master socket. This was greeted by silence. I am concerned that the master socket does not support ongoing extensions except the one plugged into the socket itself. Is my conclusion correct?
Gerard McHugh
Level 2:
Sergeant:
  • Expert 248 Answers
  • Posted on Apr 01, 2017
Gerard McHugh
Expert
Level 2:
Sergeant:
Answers
248
Questions
Helped
118852
Points
745
Take the two covers off and see if the cables to the other extensions have been disconnected
2 Related Answers
martin hogg
  • 157 Answers
  • Posted on Jan 14, 2008
SOURCE: No Dial Tone
I have found this free link on BT site for you
http://www.shop.bt.com/content/uni2/documentation/498n/025455.pdf
If the second handset works ok on the base and the first handset doesn't, then you are right...the fault lies with the first handset. There are batteries ( special type ) in the handset, it sound as if either the batteries are dead, or not charged ( try charging them for 12 hours on the good base station ) or the connection is bad.
Anonymous
  • 169 Answers
  • Posted on Jun 21, 2008
SOURCE: BROADBAND INTERNET CONNECTION PROBLEM (WIRELESS)
Every phone socket must have a working microfilter pluged as shown on the image below.
I think you need to change your microfilters as they might have blown.
microfilter2.gif&usg=afqjcnewmdhgecg08egxbhumf4zmq8g-lq
Hope this helps,
Regards,
Abdul Qayyum
This Emachine will not boot from HD or CD. The screen only says Emachine.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
How do you bench bleed a replacement master cylinder?
Put the new master in a vice or some way to hold it upright. connect hoses to the fittings where the lines connect and run the hoses in the reservoir and pump the master till there are no more bubbles. You can pump the master by using a screwdriver or socket extension and push in on the end where the peddle pushes.
1helpful
I want to change my old telephone socket for a new one, i have the BT line with a orange and white wires coming in and i have an extension with six wires coming from the box located in place numbered 1 to...
With BT there are only TWO wires, Tip & Ring... these wires simply go daisy chain from socket to socket, they ALL go on 2 & 5 in the socket. ONLY the FIRST socket should have a capacitor, and be the "Master" socket. The "LINE" also goes onto that 2 & 5 in the Master too.
http://www.britishtelephones.com/wiring/socketwiring.htm
Mar 22, 2010 • Cell Phones
7helpful
Any info on changing a brake booster on a 1996 Sierra and also help trouble shooting a master cy. Thanxlinder
a defective master has just one common symptom, a soft sinking pedal.
Instructions Things You'll Need:
  • Nose pliers
  • Ratchet and socket
  • Ratchet extension
  • Slip joint pliers
  • Wrench
  • New cotter pin
    Removing the Old Brake Booster
  1. Step 1 Park your car in a safe place with enough room to work around the front and driver side of the vehicle.
  2. Step 2 Locate the booster push rod connected to the brake pedal.
  3. Step 3 Remove the cotter pin securing the booster push rod pin to the brake pedal using a pair of nose pliers.
  4. Step 4 Release the push rod pin from the brake pedal and slide the push rod off the brake pedal.
  5. Step 5 Unscrew the four mounting nuts off the brake booster studs using a ratchet, ratchet extension and socket. You should be able to see the four booster studs extending through the firewall, in front of the brake pedal.
  6. Step 6 Disconnect the vacuum hose from the brake booster, working from the engine compartment. Use a pair of slip joint pliers.
  7. Step 7 Remove the two nuts holding the brake master cylinder to the brake booster. Use a wrench or ratchet and socket.
  8. Step 8 Separate the brake master cylinder from the booster just enough to make room for booster removal.
  9. Step 9 Pull the brake booster off the firewall and remove it from the vehicle.
    Installing the New Brake Booster
  10. Step 1 Set the new booster in place by sliding the push rod and four mounting studs through the mounting holes on the firewall.
  11. Step 2 Slide the brake master cylinder flange over the two mounting studs on the brake booster.
  12. Step 3 Start the two brake master cylinder mounting nuts by hand to avoid damage to the threads.
  13. Step 4 Tighten the two brake master cylinder mounting nuts using a wrench or ratchet and socket.
  14. Step 5 Connect the vacuum hose to the brake booster.
  15. Step 6 Screw the four mounting nuts to the brake booster working from inside the vehicle. Start the nuts by hand to avoid damaging the threads.
  16. Step 7 Tighten the four mounting nuts using the ratchet, ratchet extension and socket.
  17. Step 8 Position the brake booster push rod over the brake pedal and slide the push rod pin.
  18. Step 9 Install a new cotter pin to secure the booster push rod to the brake pedal
I have static on all three handsets yet the landline has none
sorry dont know if it was sent so i will do it again, i had same problem on a network and was advised to cut out the yellow resister in bt point ( only if a trailing socket NOT the main bt incoming socket), also have you got broad band modem ? if this is not on incoming bt socket this can cause problems? dont plug it in a extension lead use a proper cable and box on wall and plug modem direct into socket with no adsl filter ! next plug all your telephones into bt sockets through the adsl filters make sure you havent got to many phones plugged in this inclueds sky box which is a phone ?and needs adsl filter ? hope this helps leighton
1999 GMC Sierra brake problem
When you change the master cylinder it is best to gravity bleed first, then proceed to the pedal technique.
Gravity bleeding is when you just open the valve and let gravity pull the fluid down.
Keep in mind you must "prime" the master cylinder first before installing it, did you do that?
Priming the master cylinder is where you put it in a vise gently, you then take apaptors and screw into the outlets, then take tubes from the adaptors back into the resoirvor. You fill the resorvoir up with fluid and take a 3/8 extension for a socket and push the piston in and out slowly until there are no more air bubbles.
After this procedure you gravity bleed the brakes, then go on to the pedal technique.
Hope this helps,
Regards,
Abdul Qayyum
1helpful
No Dial Tone
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
Jesse Walters
Jesse Walters
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
