Question about Building Materials
Stanley Lightmaker Garage door opener lights don't turn off
Garage door light does not turn off for a long time when door is opened or closed.
6ya staff
SOURCE:
Anonymous
SOURCE: Garage door won't close
your door travel screw is set to go too far on the downward travel. you need to set the down travel. It is set to go too far down. find the screw adjustment on the unit that says close and back off the screw a full turn until door stops short of floor. then start turning screw other way until door just touvhes floor.
Posted on Mar 06, 2008
Anonymous
  • 8 Answers
SOURCE: old nutone garage door opener
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
If any thing is blocking these sensors the door will not close! Make sure nothing is in the way not even a peice of paper.
Posted on Sep 23, 2008
Don Maggard
  • 3197 Answers
SOURCE: My garage door opener won't close the garage door.
Most likely your door sensors have been bumped and are not aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
Posted on Apr 30, 2009
Don Maggard
  • 3197 Answers
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Posted on Sep 12, 2009
Don Maggard
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
Stanley garage door opener model 440. need a manual
Try Googling (Stanley)(440)(manual) without parens.
Apr 02, 2018 | Building Materials
I NEED THE MANUAL FOR MY STANLEY 8500.51 GARAGE DOOR IT WON'T CLOSE
Try searching around here to find similar or hopefully exact opener. Stanley no longer is in the garage door business, and the company that bought them out went bankrupt.
Good Luck
http://www.teknuw.com/garage-door-opener-installation-manual/stanley/
Feb 23, 2015 | Building Materials
My stanley mod6500 1/2 hp lightmaker sometimes opens and when open to set distanve it kicks out to "reset mode" ( have to switch manually from operate to vacation then back to operate ) to reset and then...
You could have a problem with the door which is causing the opener to kick into a safety mode. Release the door from the opener, run it by hand several times. If you feel it bind, figure out where it's binding and resolve that issue. Then reset your opener again and it should be fixed. If it is not binding, then most likely you have a board problem and will either need to replace the board or replace the opener. Stanley's are known for these type of board issues. I would stick to a liftmaster if you replace it.
Feb 20, 2015 | Building Materials
My Stanley 9600 opener will only work with the remote. Pressing the button in the garage, or jumping the terminals right at the two wires on the opener does nothing. This happened after an electrical...
You have shorted out your logic board. This could of been prevented with a surge protector 900 joules or higher. Whether you repair or replace get one. Stanley went out of business but you may still be able to find replacement parts online. Thanks BB
Sep 04, 2010 | liftmaster Chamberlain Garage Door Opener...
My stanley garage door opener motor runs but it won't open or close my door
If the motor runs and the chain does not then you have stripped the gears and will need to replace them. If the motor runs, the chain moves but the door does not move then the trolley is not attached or needs to be replaced. Thanks BB
Jul 27, 2010 | Digi-Code Digi Code 5202 Garage Door...
Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
Apr 01, 2010 | liftmaster Chamberlain Garage Door Opener...
Programming my 98 blazers Garage door button on dash to a stanley
Here is some programming info for the Stanley.
http://www.aaaremotes.com/standualcodl.html
The programming information for your Blazer should be in the owners manual.
Aug 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a stanley garage door opener that won't close the door
the door beams are not working properly. Let me know what you find
Apr 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
444 people viewed this question
Top Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
