Samsung Galaxy Avant 4G LTE No-Contract Cell Phone Logo
Squad Niguhh Posted on Feb 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My phone caught on fire and now the scree is black but everything still works how do i fix this help guys please
Eddie Tam
Level 3:
  • Samsung Master 294 Answers
  • Posted on Feb 10, 2016
Eddie Tam
Samsung Master
Level 3:
Answers
294
Questions
0
Helped
216853
Points
3049
Samsung Galaxy Avant 4G no contract phone: device caught on fire, everything still working except screen is black:
Hello. The question is how did it catch on fire? If we can answer this then we can proceed with what to do
Here is the section from the manufacturer:
Battery Use and Safety
Important! Handle and store batteries properly to avoid injury or damage. Most battery issues arise from improper handling of batteries and, particularly, from the continued use of damaged batteries.
Do not disassemble, crush, puncture, shred, or otherwise attempt to change the form of your battery. Do not put a high degree of pressure on the battery. This can cause leakage or an internal short-circuit, resulting in overheating.Do not let the phone or battery come in contact with liquids. Liquids can get into the phone's circuits, leading to corrosion. Even when the phone appears to be dry and appears to operate normally, the circuitry could slowly corrode and pose a safety hazard. If the phone and/or battery get wet, have them checked by your service provider or contact Samsung, even if they appear to be working properly.Do not place your battery in or near a heat source. Excessive heating can damage the phone or the battery and could cause the phone or the battery to explode. Do not dry a wet or damp battery with an appliance or heat source such as a microwave oven, hair dryer, iron, or radiator. Avoid leaving your phone in your car in high temperatures.Caution: Some applications or prolonged usage may increase device temperature. Prolonged skin contact with a device that is hot to the touch may produce skin discomfort or redness, or low-temperature burns. If the device feels hot to the touch, discontinue use and close all applications or turn off the device until it cools. Always ensure that the device has adequate ventilation and air flow. Covering the device with bedding, your body, thick clothing or any other materials that significantly affect air flow may affect the performance of the device and poses a possible risk of fire or explosion, which could lead to serious bodily injuries or damage to property.Do not dispose of the phone or the battery in a fire. The phone or the battery may explode when overheated.Do not handle a damaged or leaking battery. Do not let leaking battery fluid come in contact with your eyes, skin or clothing. For safe disposal options, contact your nearest Samsung-authorized service center.Avoid dropping the cell phone. Dropping the phone or the battery, especially on a hard surface, can potentially cause damage to the phone and battery. If you suspect damage to the phone or battery, take it to a service center for inspection.Never use any charger or battery that is damaged in any way.Do not allow the battery to touch metal objects. Accidental short-circuiting can occur when a metallic object (coin, key, jewelry, clip, or pen) causes a direct connection between the + and - terminals of the battery (metal strips on the battery), for example when you carry a spare battery in a pocket or bag. Short-circuiting the terminals may damage the battery or the object causing the short-circuiting. Important! Use only Samsung-approved batteries, and recharge your battery only with Samsung-approved chargers which are specifically designed for your phone
WARNING!
Use of a non-Samsung-approved battery or charger may present a risk of fire, explosion, leakage, or other hazard. Samsung's warranty does not cover damage to the phone caused by non-Samsung-approved batteries and/or chargers.
Do not use incompatible cell phone batteries and chargers. Some websites and second-hand dealers not associated with reputable manufacturers and carriers, might be selling incompatible or even counterfeit batteries and chargers. Consumers should purchase manufacturer or carrier-recommended products and accessories. If unsure about whether a replacement battery or charger is compatible, contact the manufacturer of the battery or chargerMisuse or use of incompatible phones, batteries, and charging devices could result in damage to the equipment and a possible risk of fire, explosion, or leakage, leading to serious injuries, damages to your phone, or other serious hazard. UL Certified Travel Charger
The Travel Charger for this phone has met applicable UL safety requirements. Please adhere to the following safety instructions per UL guidelines:
FAILURE TO FOLLOW THE INSTRUCTIONS OUTLINED MAY LEAD TO SERIOUS PERSONAL INJURY AND POSSIBLE PROPERTY DAMAGE.
DANGER - TO REDUCE THE RISK OF FIRE OR ELECTRIC SHOCK, CAREFULLY FOLLOW THESE INSTRUCTIONS.
FOR CONNECTION TO A SUPPLY NOT IN NORTH AMERICA, USE AN ATTACHMENT PLUG ADAPTOR OF THE PROPER CONFIGURATION FOR THE POWER OUTLET. THIS POWER UNIT IS INTENDED TO BE CORRECTLY ORIENTED IN A VERTICAL OR HORIZONTAL OR FLOOR MOUNT POSITION.
Taken from:
http://www.samsung.com/us/Legal/Phone-HSGuide
which is included in the Samsung Galaxy Avant User Manual:
https://www.metropcs.com/content/dam/mpcs/faqsandsupport/samsung/Samsung%20Galaxy%20Avant%20User%20Manual.pdf
How to proceed:
1. You could, if for any reason the phone caught on fire, including the above scenarios contact Samsung direct, just so that they are aware this incident happened. Even if it was your fault, they should know that it happened. The manufacturer may ask you to ship it back to them.
This is the contact info:
Samsung Telecommunications America (STA), LLC
1301 E. Lookout Drive Richardson, TX 75082
1-800-SAMSUNG (726-7864)
1-888-987-HELP (4357)
Electronics Appliances Tablets Laptops Phones TVs Samsung US
2. Outside of contacting the manufacturer, you could take it to your local repair shop and ask them for a damage assessment or to diagnose the repair of the device. There maybe more than just the screen that is damaged inside the case. Cost could exceed $300 in damages.
3. You could also take it to your Service Provider's local store and tell them that it caught on fire. Ask them if you can get a replacement and a temporary phone if need to wait for the replacement. If you have insurance on it, you should be covered. If not, it's up to whatever they say. Doesn't hurt to ask.
Claude Kayser
Level 3:
Top Expert:
  • Samsung Master 9,098 Answers
  • Posted on Feb 09, 2016
Claude Kayser
Samsung Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066422
Points
28436
My Samsung Galaxy S3 exploded last night while I was ...
https://www.reddit.com/.../my_samsung_galaxy_s3_exploded_last...
RedditMay 27, 2013 - Will Ambient Display get better? ... (I charge my phone while I'm sleeping on my bed right next to me) ... Half asleep, I jumped out of bed and turned the light on, only to see that my phone was just beginning to go on fire. ..... Yup, I wouldn't bother trying to contact Samsung for now (since the appropriate ...
About a month ago, my Galaxy S4 caught on fire. Samsung ...
https://www.reddit.com/.../about_a_month_ago_my_galaxy_s4_ca...
RedditJul 26, 2014 - SamsungAbout a month ago, my Galaxy S4 caught on fire. ... The purpose of my calls to Samsung, when the replacement phone never arrived, was ....Google Now is great and behaves the same on HTC devices like the HTC One m8. ......The G3's dark-ish screen and lesser battery life are turn-offs for me.
Samsung Galaxy S4 mobile phone catches fire after owner ...
www.dailymail.co.uk/.../Mobile-phone-catches-fire-owner-lea...
Daily MailApr 9, 2014 - Civil servant wakes up at 5am to find her PHONE on fire and ... rose from her Samsung Galaxy S4 and it burned her carpet; She is now ... my boyfriend got up to go to work and looked at my phone to check the time. ... 'Even though it was dark I could smell the smoke. I picked it up and the screen sparked.
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 • Cell Phones
My canon 20d is playing up when i switch on my canon starts firing flash and i dont see my menu scree when pressing menu button please help
That sounds like a bad main board problem what you can do is try and upgrade your firm ware that might update and fix the problem if this doesnt work it will have to be sent off to a repair center
1helpful
My iphone's scree doesn't work anymore, even the
Try a reset. Hold down the power key at the same time as the round home key until
phone powers down. Release buttons only when you see the apple logo,
then wait a min or two for phone to re-boot. You will not lose any data on the phone.
If this does not work, try an actual system reset. Sync iPhone to computer to back
up essential data ie contacts apps etc, then go to settings general and reset. Reset
all settings as a last resort. This will give you a fresh start and should sort out
the majority of any bugs the phone has. A resync with you computer will restore apps etc.
Hope this helps and if so please vote.
Thanks
Jim
2helpful
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
3helpful
2answers
Paper caught fire in microwave. microwave power
check breaker in your home electrical panel...make sure all are on
2helpful
Smoke - My dishwasher was working yesterday when all of
This is a serious issue, you may need to contact the manufacturer about it. Check for recalls as your dishwasher is basically a fire hazard. There is a fan in the door that may caught fire or the door latch mechanism caught fire. Perhaps another part caught fire.
I also may recommend you to open a claim with the manufacturer about smoke damages or any other damage that your property may have.
Good luck.
After changing wiring harness car will not start
I'm going to give you a website addy, if you go here the guys on here will definitely be able to help you. Its a group I'm a member of from Nova Scotia all these guys do is fix, repair and specially mod vdubs you will get your answer there for sure dude. Good luck
http://www.customobsessions.com/index.php
just copy and paste that in your browser.
Scree went black
http://www.modmymoto.com
this site rocks
this is a link to a file that would show you how to fix flex it. you have to download it, but it works...
http://www.modmymoto.com/forums/downloads.php?do=file&id=678&act=down
My motorola razr v3 screen don't work
This happens alot to my phone... I take my sim card and put it in a spare cell phone that i have and then switch it back into my razr, it works everytime
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
