Symbol MC9090 Barcode Scanner Logo
Felipe Manuel Campo Heredero Posted on Feb 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i activate teh scanners? I am trying to read on an excell file or txt file, but the scanner does not work. How can i enable it? Thanks
Kelly
Level 2:
Habit-Forming:
New Friend:
  • Symbol Expert 60 Answers
  • Posted on May 04, 2016
Kelly
Symbol Expert
Level 2:
Habit-Forming:
New Friend:
Answers
60
Questions
0
Helped
75619
Points
287
Most likely you need to download and install Datawedge. See here for solution. Symbol Motorola MC9090 Will Not Scan
5 Related Answers
A
Anonymous
  • Posted on Oct 07, 2008
SOURCE: How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Jul 29, 2009
SOURCE: Motorola HC700 Scanner Software
As far as i know Datawedge will work with the scanner, DataWedge provides a convenient mechanism for non-scanning awareapplications to receive data from embedded or connected datacapture devices. It allows the user to capture data into anyapplication that accepts keyboard input. It supports four types ofData Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers andSerial Data Input. It provides user with text/hex data formattingand prefix/suffix facilities. Description
  1. New Test and Log Display.
  2. Improved DataWedge Startup Time for MSR and RFID
  3. Gen2 RFID Support
  4. Device enable/disable persistence over cold boot
  5. Virtual Key Support in Prefix/Suffix
  6. Performance improvements for MSR
  7. Enable Serial Interface on startup
  8. Support added for Event based Serial reading.
  9. Delays regarding RFID are fixed.
  10. Several Barcode character mapping issues fixed.
If for some reason the software doesn't work then have a look here @ Redbeam >>>>>>
http://www.barcodemegastore.com/catalog/redbeam/
Good luck and if you need anymore help please post back.
Symbscanners
  • 74 Answers
  • Posted on Oct 16, 2009
SOURCE: LS4278 scanner can't read digits
Hi, try scanning French Windows barcode from the USB section of the LS4278 Product Reference Guide. The barcode is on Adobe page 147 of 414. You may also have to scan the Enable Keypad Emulation barcode from Adobe page 150 of 414, but I would do this only after testing with the French Windows setting first. I suggest saving a copy of the document before printing the barcodes just to make it easier to print. Hopefully this will resolve the issue.
Yogger
Max Quido
  • 117 Answers
  • Posted on Nov 18, 2010
SOURCE: Symbol MC9090 Barcode Scanner cannot enable
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software. Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Victor Balbuena
  • 6 Answers
  • Posted on Mar 01, 2012
SOURCE: MC70 Barcode Scanner: how do i enable linear scanner on my symbol mc70...
What you need to do is install a scan utility to enable your scanner. The following postings are old anyone is still having issues?
Cant open Excel files. Not even from emails with Excel attached
either your MS Office Installation is currupt or your system in infected with a virus.
Please scan your system using a good virus scanner. (Please uninstall any prior scanner if you have and pl avoid using McAfee for the time being).
Now open your excel go to Office button
Office Button --> Excel Options --> Resources --> Diagnose
if problem comes during diagnosis, please connect your system to internet and if fails, please reinstall office again.
Good Luck
Zulfikar Ali
[email protected]
tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 • Computers & Internet
Hello, i am new to using the barcode scanner can you please tell me how i can use it. I have it enabled but it seems like it is not working, because when i have any bar code in front of the scanner and...
The barcode reader can only be used by any application developed. To read barcodes for a program like notepad, excel, etc.., then there is a program that sends the reading of the scanner into the keyboard buffer. You can also read barcodes with the camera. The buttons are also programmable.
Printer Scanner does not produce .doc or .txt files
You can, however this is acquired at the stage just before you scan the document. You need to specify what kind of document you want as the output.
I want to read text file which is located in c drive using java code can anybody help me out
import java.io.*;
import java.util.Scanner;
public final class ReadWithScanner { public static void main(String... aArgs) throws FileNotFoundException {
ReadWithScanner parser = new ReadWithScanner("C:\\Temp\\test.txt");
parser.processLineByLine();
log("Done.");
* @param aFileName full name of an existing, readable file.
public ReadWithScanner(String aFileName){
fFile = new File(aFileName);
/** Template method that calls {@link #processLine(String)}. */
public final void processLineByLine() throws FileNotFoundException {
Scanner scanner = new Scanner(fFile);
try {
//first use a Scanner to get each line
while ( scanner.hasNextLine() ){
processLine( scanner.nextLine() );
finally {
//ensure the underlying stream is always closed
scanner.close();
* Overridable method for processing lines in different ways.
* <P>This simple default implementation expects simple name-value pairs, separated by an
* '=' sign. Examples of valid input :
* <tt>height = 167cm</tt>
* <tt>mass = 65kg</tt>
* <tt>disposition = "grumpy"</tt>
* <tt>this is the name = this is the value</tt>
protected void processLine(String aLine){
//use a second Scanner to parse the content of each line
Scanner scanner = new Scanner(aLine);
scanner.useDelimiter("=");
if ( scanner.hasNext() ){
String name = scanner.next();
String value = scanner.next();
log("Name is : " + quote(name.trim()) + ", and Value is : " + quote(value.trim()) );
else {
log("Empty or invalid line. Unable to process.");
//(no need for finally here, since String is source)
scanner.close();
// PRIVATE //
private final File fFile;
private static void log(Object aObject){
System.out.println(String.valueOf(aObject));
private String quote(String aText){
String QUOTE = "'";
return QUOTE + aText + QUOTE;
3answers
Hi, I'm writing a php page to be used on the MC9090 and I want the laser to be activated when focus is on a specific input box. Seeing as I'm new to the MC9090 scanner I don't have a clue where to start....
I'm not sure if you can trigger the scanner based on a web field but you can just enable the Data wedge software which will allow the scan to input anywhere you have the cursor. The scanner will be "active" all the time but won't actually scan until you pull the trigger. You can download the datawedge software from www.symbol.com.
Datalogic QS6500BT barcode scanner and 2D codes
Usually some symbologies are disabled at default.
i think you need the manual and scan the barcode to enable it for scanning.
the links is:
https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=R44-2816A
it's chapter 6-191 or page 279 in pdf.
you have to begin with scanning "Start" en end with scanning "END"
becarefull with printing this page and not the whole manual. there are 336 pages.
good luck
6answers
A Communication Problem Occurred. Open log file
There is a textfile named scanwise in the directory of scanwise (version 2.0). There could you find some more information about your communication problem. Sometimes the info is a little bit short, but maybe this info can help you to get additional support.
Cheers,
Ferry
3answers
Scan button do not function
open the OTL program.
go to 1 - Test Apps
go to 6 - Next Page
go to 1 - Auto Wedge On
do the tests now ;)
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
