SOURCE: I have a Redfield 'LO-PRO' rifle scope, 3X9
It doesn't sound like anything's broken, it sounds like the scope has shifted in the rings, as you said "they are not straight up and down anymore", which won't effect your accuracy at short ranges, but if there's long ranges (more than 100 yards) you're going to be off some.
You can loosen the ring screws until the scope will turn, either 2 or 4 screws that hold the two halves of the ring together. There are numerous tools to help you align the crosshairs, but when I do this job I just square-up the reticle (crosshairs) by looking at the center of the reticles and let your eye follow the bottom crosshair down and make sure it is centered on the back of the bolt or receiver. If you need help doing this job, take it to your local gunsmith, he'll be able to square these up for you and boresight it.
Hope this helps, Mark the Gunsmith
SOURCE: scope wont shoot good groups
That can get expensive, I had the same problem, bought a Bushnell scope and it went everywhere but on the target, couldn't hold it steady, with my win mod 70 in 308 with heavy barrel, I said that's it, I went and bought a Leupold, no problems since. I don't know what was wrong with the Bushnell, just couldn't handle the blast I guess. I put he Bushnell on my bolt action 223 and haven't had a problem with it, but always expect one because of what happened before. I don't remember the model number, but it was a 3x9. Hope this helps.
SOURCE: Have 2 30/30 Winchester Midel 94 rifles serial #`s are 1662105 and 2313533 how old are they ?
the 1662105 was 1949 (64 years)and the 2313533 was 1958 (55 years) at 90% $500 each and if all orginal,,20 inch barrel , w/o saddle ring The 30-30 was the most common and most popular so prices are not as high as other calibers. And it is condition,condition,condition
SOURCE: Winchester Repeating rifle serial #1c11659 - what model is it, what year is it and what is the value
On the Winchester Website there is a link to a pdf file that has Serial number information by year / model. I searched the Document but did not find a match for 1c11659. It does state that serial number info is not complete for a variety of reasons. Here is the link - maybe you can find one similar to yours: http://www.winchesterguns.com/customerservice/qna/detail.asp?id=296
SOURCE: Serial numbers for Weatherby rifles starting with VL27+++. What is model name?
Vanguard is the model
