Question about Milwaukee Drills
When using my milwaukee m18 magnum drill halfway through drilling a hole the drill stopped as if the battery were dead
When using my milwaukee m18 magnum drill halfway through drilling a hole in timber the drill stopped as if the battery were dead thinking nothing of it i got the other battery out of the box a placed it in the drill when i tried to drill the hole the drill did nothing , so then i tried the battery's in my other drill and nothing happened as if both battery's were dead so then i tried the battery from my other drill which i checked it were working before putting it in to the m18 magnum and nothing happened so i need help on this please as i have a drill that stopped three of my battery's working and the drill its self still isn't working
    New Friend:
    Problem Solver:
  • 5 Answers
Dear Chris Kelliher, Hi,
According to your explanation, i guessed that the electronic circuit for driving the motor of drill, has gone off. In such a case, the motor is either driven under variable frequency drive system, Power transistor (FET, IGBT may be used) or SCR control circuit. under the cover of drill there is an electronic circuit, which may be damaged. It should be rectified by some technical expert. here is a link of services provider, https://www1.milwaukeetool.com/PartsAndService/Repair/Default.aspx?chrome=false
If you are unable to reach the service center just download the form from the link above an fill it and shipped your part to the related company with free shipment. If you can check it personally then check it. i will guide you whatever possible. Service Milwaukee Tool
Posted on Mar 26, 2016
    Top Expert:
  • Milwaukee Master
  • 66,042 Answers
Posted on Feb 12, 2016
6ya staff
SOURCE:
Milwaukee 2601-20, pull trigger, light comes on but chuck won't turn. It seems as though the chuck moves slightly but that's all
Is the charger working properly? Do you have any other M18 tools you can test the battery with? If the batteries are ok - these drills have micro-controllers in them (they also "drive" the battery guage LEDs). Short of taking it apart...not much you can do. Supposing it was apart - there's lots of videos on YT that show you how to check for cold solder joints, wiring problems, defective switches or controller boards.
Mar 28, 2017 | Milwaukee Drills
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
Milwaukee m18 impact non functional. Light stays on when battery is inserted and when trigger is pulled drill spins for a second then stops
Brand NEW battery for MILWAUKEE M18. Quick charge with automatic constant current control prevents battery from overcharging, short circuit, and electric shock. Perfect fit for your power tool battery!
http://www.drillbattery.com.au/buybattery.php/milwaukee_M18_power+tool+battery.html
May 14, 2014 | Drills
Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Dec 05, 2009 | Milwaukee 2610-20 18V Cordless M18 High...
Looking for parts list for Milwaukee 2610-20
Hi, this website has parts diagram for your tool.
Hope this helps.
http://www.ereplacementparts.com/milwaukee-261020-ser-b53a-volt-magnum-1234-driverdrill-parts-c-131_5138_16331.html
Aug 18, 2009 | Milwaukee 2610-20 18V Cordless M18 High...
Drills Logo
782 people viewed this question
Top Milwaukee Drills Experts
Mike
Domenico Grillo
Andrew Taylor
Andrew Taylor
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
