easiest way is to download the HP MFP configuration wizard and run that. It will setup a shared folder on your computer and then add a scan to network folder icon for your computer on the MFP. You will need the user name and password that is used to log into Windows to set this up.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Assuming your scanner is installed already, what you need to do is log into Windows Photo Gallery (Vista) and click on FILE at the top left. When the drop down bar engages, you should look for IMPORT FROM CAMERA OR SCANNER and click it. Then a new window will open up and you'll have to pick your device (HP Laserjet M3035). At this point check your settings, and make sure your scan is ready, then click on either PREVIEW or SCAN. Then when it is done scanning, you will have to go to the folder you saved it in to view it. (Xp Similar)
