place a turned on torch against the tv screen while tv on can you see a picture ? If yes then back light problem possibly inverter that powers the back light.
You tubesearch on tv faults for more insight on possible causes of black screen or no screen on Tv's
if no picture with torch then it might be main board .
Check you tube for ideas on possible causes.
First, make sure the batteries are fresh and installed correctly. Turn on the camera, if you get an opening screen, your camera should be OK. Press the menu button and navigate to screen options where you should be able to turn on the screen to take pictures.
If there is no opening screen when you turn on the camera (and you are sure the batteries are good and in properly), then try to take some pictures without the screen. If the camera takes good pictures, then the screen is dead. You can continu to take pictures with it in this condition. I do not think they are worth fixing, though.
If the camera does not take good pictures or no pictures then the camera has failed or dead. Your best solution is to replace the camera with a newer, better one, More pixels, greater optical zoom, quicker start time and so on.
Did you accidentally press the DISP or DISPLAY button on back (it turns the screen off to save batteries). If so, press this button again to turn your LCD screen back on.
this will perform an install that will eraseeverything and start over.
Remove all CDs or DVDs from the optical drives.
Turn off the computer using the normal Windows shut down process.
After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
Turn on the computer. To start recovery, at the prompt press the F11 key. View PictureNote: If this is the first time the computer has been started to the recovery partition, insert the System Restore CD when prompted and then click OK. View Picture
Files copy. View Picture
In the System Restore Options dialog box, select Full System Restore (Destructive), and then click Next. View Picture
In the System Restore - Format and Recover dialog box, click Yes. View Picture
In the System Restore dialog box, click Restart. View Picture
The computer restarts.
Drivers and applications are installed. View PictureNote: The following Out of Box Experience (OOBE) screens may vary slightly between models.
In the Welcome to Microsoft Windows screen, click Next. View Picture
In the Are your speakers working? screen, click Yes! I can hear the music!, and then click Next. View Picture
In the What time zone are you in? screen, select the appropriate time zone, and then click Next. View Picture
In the End User License Agreement screen, click Yes I accept for both EULAs, and then click Next. View Picture
In the Help protect your PC screen, click Help protect my PC by turning on Automatic Updates now, and then click Next. View Picture
In the What's your computer's name screen, type a name for the computer and a description, if desired, and then click Next. View Picture
In the What's your Administrator password? screen, type the appropriate information, and then click Next. View Picture
In the Is this computer in a domain? screen, click Skip.
The computer checks the Internet connectivity. Please wait. View Picture
In the How will this computer connect to the Internet? screen, select the appropriate option, and then click Next. View Picture
In the Do you use a username and password to connect to the Internet? screen, select the appropriate option, and then click Next. View Picture
In the Setting up a high speed connection screen, select the appropriate options, and then click Next. View Picture
In the Ready to register with Microsoft screen, to register with Microsoft after the OOBE screens are completed, select No, not at this time, and then click Next. View Picture
In the Thank you screen, click Finish. View Picture
Installation is complete. Any application that shipped on a separate CD can now be installed. It is recommended to update the antivirus definitions and perform Windows Updates.
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
bad voltage regulator - BA09FP requires a bit of tech experience to replace, but its relatively easy. It took me about 1 hour to replace mine. If you need clarification on this, email me at Doin12volt at yahoo
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
